Question about Miele W865 Front Load Washer
Meile novotronic w853 washer- Intermittently the machine start the main wash without fill up water but when I select later ?separate rinse" then it fill up the water,it also sometimes stopped for 20 minutes without moving in "DRAIN/FINEL SPIN" and then the DRAIN/FINEL SPIN light start blinking together with the red light "check inline" then the "check inline" go off but the DRAIN/FINEL SPIN light stay blinking. Can it be related to the Main Motor brushes? hanks
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
arikrom
  • 528 Answers
SOURCE: how do I check the filter
the filter is on the bottom left side in the front panel
also the drain pump is there.
Posted on Jan 06, 2010
  • 30 Answers
SOURCE: Hi Miele Novotronic W853 washer, wont drain
Could be blocked pump or pump hose.
also could be a blockage in the collecting tank .
Posted on Mar 18, 2010
  • 2509 Answers
SOURCE: Meile Novotronic W 828 Washing
It means what it says! i.e. water is not getting into the machine, the inlet hose or path is blocked or the inlet valve has failed. You need to turn off power and water and check it is getting water through inlet hose and that the inlet filter is clear, the filter can be seen on the valve when you remove the hose. You will need to open the machine to check the inlet valve and tubing. Hope that helps please vote
Posted on Feb 04, 2011
Daniel S
  • 4323 Answers
SOURCE: My meile novotronic 1986 frontloading
Hi
You'll have to check the drain pump assembly located inside the bottom front panel of the unit. Take it out and clean it completely to solve the issue. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 08, 2011
How to check a miele novotronic anti syphon unit
During rinse, water usually flows through the softener dispenser. The cup fills up and a small siphon tube triggers a siphon action
which pulls the softener and water into the washer. This siphon tube is probably blocked with crud. See if you can pull a small cap like part out of the softener dispenser area. Clean both the inside of the cap and the hole under it. This will allow the water to flow into washer instead of flooding.
Jul 06, 2016 | Miele Novotronic Premier 500 Front Load...
When starting the machine its starts washing without filling
This could be because the water level fill switch assembly is bad and it is telling the washer that it is already full of water.
Nov 27, 2013 | Maytag Centennial MVWC500V Washer
Main wash light flashing
I have the same problem, try checking the water temperature, it seems that this light indicates a heating ciruit problem. The next step is to check continuity of heating element. These are readily available from meile and other suppliers/ aution site on web.
Nov 30, 2012 | Miele Novotronic Premier 500 Front Load...
When cold water is selected the washer does not start or if cold rinse is selected it does not fill or go any further in the cycles
Cold water valve is faulty. on hotter washes it will fill with hot but all rinses are cold fill so will stop waiting for water at first rinse.
Aug 03, 2010 | Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Water only fills the machine in certain parts of cycle
a 90* wash will fill mainly with hot water / a 40* wash will fill mainly with cold water, this is normal action, rinses fill up with cold water only
is this what you are describing, if so thats normal, especially if its doing the job correctly
Oct 14, 2007 | Frigidaire GLTF530DS Front Load Washer
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Miele W865 Front Load Washer Logo
129 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
