Question about H.D. Hudson 96302e 2gal Stl Sprayer 1 Ea 2845907
Valve problems, nothing comes out,not pluged, i take it apart,sometimes it works,dont no if i should fix or get a new one.[model71132]
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Dont bother trying to fix it when they go wrong they go WRONG it is not worth the hassel Buy new one
Posted on Jul 26, 2010
We have no hot water coming out of our bathtub faucet. We took it all apart and water is only coming our of the cold side of the pipe
there is probably a shutoff on the rough-in valve in the wall. Sometimes the seal in that comes apart and blocks the water. Get new stem for valve. Unscrew the nut, replace stem, tighten nut. Clean inside valve before u put new one in.
Oct 10, 2015 | Delta & Single Handle Shower Faucet
Fix toshiba satellite laptop black screen
Try pluging the laptop into an external monitor and see if you can see the screen. Some laptop models you have to press the Fn key and another key to switch to the external.
Sep 21, 2013 | Computers & Internet
Air Ease Ultra SX 80 thermostat "clicks", go look at furnace, there is an orange glow, but no blower, no flame, no heat!
Check for the inducer motor it should be running. If not then change motor. If so take the vaccum line of and blow into it. Do this when it first starts. If it opens the gas valve and works it is clogged or a bad pressure switch. If still not working. There are a series of safety switches,they are easy to see. Start jumping them out to find the bad one. They are located around the burner.
Mar 01, 2013 | Heating & Cooling
Check engine light comes on at one mile distance. Repaired vaccum leaks + tried changing O2 sensor with new one on drivers side + swaped O2's from left to right side to see if code would change.No...
oil burning bad lifter bad valve pluged converter head might be cracked bad injector.you got the codes to fix itand you did but there a reason this problem keeps coming up find it before it dont run I dont know this code but the reason it comes up is a problem look in to it moore ......
May 08, 2011 | Ford Explorer Cars & Trucks
Upon pluging in new microwave nothing works nor does any lights come on.
have you tryed the FUSE in the plug or plug it in some dont ave lights on the front of them only way to see is to open the door if the in side light is on then its ok if no light then check the fuse in the plug by putting one in you no to be working if that dont fix it take it back to the shop were you got it for and tell them its not working ok
Mar 25, 2011 | Vacuums
Air compressor will not restart at cut in pressure. i have removed line from head and found no backpressure but motor will start every time. replaced switch with new unloader valve, still have same...
the start windings are probly burnt. does it hum when it his cut in. i had one the same. u bleed it down to nothing and it would start but slow. once its up to speed the motor switch snaps and u go to the other set of wires in the motor. it will work good till it cuts out. like u said no back pressure at the head. but wont anyway. well if u try to start it its not long and the short pipe to the check valve builds up if u start from empty the check valve can open and let the air out while it slowly speeds up if this sounds like ur problem then u need a new motor i had one i took apart and the start windings, the thinker shorter ones, were stuck together because the clear insulation melted together. i spit them apart using a screwdriver and gooped them up with that liquid black tape. put it together and nothing. found out i broke one. so i twisted it together good and put it all together again and pluged it in. it still works today. it was just a temp fix but i figure untill it stops working again im not going to replace it.
Nov 18, 2010 | Air Tools & Compressors
The only thing that works on my heater is the rear defrost and when i try to get heat nothing happens can you please tell me why
usually i have found the valve from the inlet manifold going towards the fire wall on most vehicles is blocked or broken , it may also be electronic on your car but , on most cars it fits between water hose about 3/4 to and 1 inch in diameter coming from inlet manifold , this is on oposite side of motor from exhaust , and usuall has a few clamps holding it on . this would be first thing i would check , sometimes cleaning this valve fix's your problem .
ask a freind which hose if you are unsure (somebody who has a little experience with cars .)
i dont have your model car but i have fixed other cars with the same fault !
Nov 10, 2010 | 2000 Nissan Maxima
Use 4.0 valve cover on 90 4.2l engine omit pcv valve use breather
not a good idea, engines rely on negative pressure(vacuum) for seals on crank and camshaft seals
also for emission standards, sorry
Jun 30, 2010 | 1990 Jeep Wrangler
Code said egr valvr did not fix problem
You probably have a pluged intake manifold. Sometimes you can just run a coat hanger wire to unplug the passage . In extreme cases you have to remove the intake to clean it
Nov 12, 2009 | 1985 Ford F150
I have an 01 Kia Sephia. When I try to fill the gas tank it trips the shu-off right away. Seems like an air vent blocked but I can't find it.
the charcoal canister has come apart and the charcoal particles have traveled thru the vent system and pluged the fuel tank vent valve in the top of the tank, after the canister is replaced, youll need to replace the canister close valve, and probably drop the tank and clean out the vent hoses and remove and clean out the vent valve also, when the canister comes apart, its a mess.
Oct 15, 2009 | 2001 Kia Sephia
H.D. Hudson 96302e 2gal Stl Sprayer 1 Ea 2845907 Logo
85 people viewed this question
Top H.D. Hudson Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a H.D. Hudson Garden Expert? Answer questions, earn points and help others
