Question about Whirlpool GS5SHAXN Side by Side Refrigerator
Flap on inside of ice shute not opening to allow ice to come out
I have a Daewoo side by side fridge the flap which opens to allow ice to come out from the icemaker is not opening, I suspect there is a solinoid which has failed the main problem is how to get at it without damaging the fridge. Do you have to remove the rubber seal round the door or what, any advice would be appreciated. Model no is FRSU20DAI 19.1CF
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
It may be more serious, but first check for ice around the sides of the ice delivery chute. Indeed it could be the solenoid.
Posted on Sep 21, 2017
5 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: ice dipsencer door flap
You have a Mechanism delay come out. it holds the flaper open and close it slowly. is the end with the arm on it broken you will have to disassemble the dispenser front to get the new one back in... let me know Thanks
Posted on Aug 18, 2007
  • 20 Answers
SOURCE: Ice Dispenser flap is dangling
You need a ice door kit. It's either part # 8201756 or 8201758. I'm not sure which part number it is but you can go to ddapplianceparts.com and go to the left hand side of the screen and type in the 1st part number and if it says it's a ice door kit, then that's the part you need. We replace a lot of these.
Posted on Aug 12, 2009
beamerguy740
  • 65 Answers
SOURCE: icemaker will not dispense ice. the bin is
You are correct. Motor or Board. See if you can turn auger motor by hand It is geared and should be hard to turn but not locked up. You can also remove auger motor assembly. Plug it into 110v it will run, (replace board) or not. (replace auger motor).
Posted on Nov 15, 2010
  • 218 Answers
SOURCE: Flap on Ice chute came off I need to put it back
I'm in the middle of the same problem on my own refrigerator right now. The flapper swings on a steel pin which passes through a stationary plastic tab. That plastic tab can break off, allowing the door to fall out of position. Look up into the mechanism to see if this is your problem. Whirlpool makes a modification kit, part #8201756. It's not on the original parts list, so do a web search for Whirlpool 8201756. I hope this helps.
Posted on Jul 10, 2011
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Rubber flap in ice shute on PSC23NG does not close causing ice build up
you might what to contact the fridge manufacturer,,make sure to write the model # and serial # and there should be an 800' # to call, as all fridges are different
Feb 20, 2013 | Refrigerators
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Sounds like marbles or ice dropping in refrigerator (not freezer side). Looking into vent in back upper left corner, noise seems to coincide with a flap going up and down. The flap movement is being...
The flap is what open and closes to allow more or less cold air in from the freezer. There could be ice buildup inside the freezer causing this or a mechanical noise of the flap and motor running. See if you can see it from the freezer side of the vent.
May 26, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Oct 21, 2007 | LG LFX25960ST Stainless Steel French Door...
Kenmore Elite Refig. model 54602300
problem is due to ice flap closing too quickly, depending on model some have a delay before flap closes, ice should stop falling 3 seconds before flap closes. Regards Advisor
Aug 18, 2007 | Kenmore 54602 / 54604 / 54609 Side by Side...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
73 people viewed this question
Top Whirlpool Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
