Question about Soyo Slot 1 SY-6BE+ Motherboard
Front cable configuration
I unpllugt the front cable from my mobo
and when i try to put it back
i see thet is nothing is wreating on
the mobo
how can i put it back
slot 1 sy-6be mobo
  • shalom rozentweig Apr 24, 2008
    you halp me ok i solve my problem
    it send me to pdf file then another problem accore
    how to open it
    but then automticly get solution from windows
    i try to say they you have to explain all the way
    including how to open the pdf file
    thanks again
    shalom from israel
To late
thenks again i hop to have more problem to be solve
its good to larn from you
by
shalom
Posted on May 17, 2008
  • 655 Answers
Click here for soyo support
select your model no. and get manual from there.
Thanks
Iqbal
Posted on Apr 22, 2008
  • Iqbal Husain
    Iqbal Husain Apr 24, 2008
    shalom,
    its great that you have solved your problem.
    Regarding How to open PDF:
    • Its allready supposed that like OS you should have some essential thirdparty software, like Acrobat reader, Flash Player, RealPlayer....etc and many more. These all are free and you can download.
    • Adobe Acrobat reader is frequently used for PDF, and most companies are producing their manuals, user's guides etc in PDF format.
    Really I did not think that this type of problem may occer.
    Sorry for inconveniance.
    Anyways thanks for your rating, feedback and suggesstions.
    Thanks
    Iqbal
Putting wires back on motherboard
Which type of wire's are they? If you are talking about mobo onboard speaker and front led cables. It should be written on motherboard itself. You need to take it to bright light and try to find out. If it is speaker cables it should be in spkr word. If iti s front LED then it should be colour coding on motherboard. Good luck with that.
Jul 16, 2012 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Intel D815EEA2 mobo won't boot - no clue to why not.
I know, this is a very frustrating situation...
Unfortunately, the only reasonable way to find out what's wrong is to swap components with a reference system, until you found the defective part. I hope you have another P3 system available to swap parts.
I would do it this way:
  • First check that the power button is connected correctly.
  • Swap the memory from the faulty system to the reference system.
  • If ok, put it back into the faulty system and connect the power supply from the reference system (or some other known good one) to the faulty system.
  • If this doensn't help, swap the CPU from the faulty system to the reference system.
  • If the CPU is ok, the motherboard seems to be defective.
Mar 24, 2010 | Intel Desktop Board D815EEA2 Motherboard
I have a Gateway tower (gt5026e) with an Intel mobo (E210882). I recently upgraded the video and purchased a pcie nvidia card. I knew I would need a new power supply (300w wasn't acceptable for the card)...
you may have dislodged something as you carried out the upgrade - Check all the cables are seated correctly - also check the memory is correctly seated does the machine bleep at all this will give an indication of what the problem may be ------ the number and pattern of the bleeps
the next step would be to remove all unnecessary devices, like the CD , DVD , spare drives - getthe machine to a minimum state of just PSU, MOBO, CPU, Memory, harddrive, graphics and see if that boots
also as you have upgraded the video card can you put the old one back in....
Mar 21, 2010 | Dell Dimension 1100 PC Desktop
No power at all. Changed PSU and still no luck. MOBO light comes on but nothing else. I need to check the connections to the J9G1 jumper too.
If you changed out the power supply, and checked all the cables, checked and made sure the power switch was on, checked the switch for 110/220 on back of computer, confirmed it was plugged into a good socket, check the cable that connects the motherboard to the power supply with a voltmeter that may help in isolating the problem. The small motheboard light is on beause the CMOS battery is still supplying the board with some electricity.
On the jumpers, couldn't get you a diagram they are not avabilable; cover pins 1-2 is normal mode; cover pins 2-3 is to configure BIOS; none the BIOS will attempt to configure itself but you have to boot from a cd rom or diskette. Hope this helps. If none of those works then its the motherboard.
Pls rate this solution.
May 07, 2009 | Computers & Internet
D102GGC2 will not do anything!
Hi there. Have you tried running the system as a barebone?
What I mean by this:
Disconnect everything from the mobo, all memory sticks, cables, wires, and any PCI/AGP cards you may have.
If you have more than 1 memeory stick, only put 1 back in. Connect the power switch to the mobo.
Now connect the power supply to the board.
Connect the monitor to the On Board VGA port.
Now turn it on. Let me know what, (if anything), happens.
Tim
Apr 25, 2009 | Intel D102GGC2 Motherboard
D102GGC2 mobo problem
I have built quite a few PCs and I have often found the same problem when trying to boot for the first time. An old trick that might help is to repeatedly energize then drain the PC electricity.
Do this by plugging in the PC momentarily then unplugging it then immediately pressing the power button on the PC while there is no power hooked up. Do this several times over and over again in quick succession. Finally turning on the PC with the power connected. If the power supply on the PC has a switch on it you may use that instead of actually plugging and unplugging.
Also you might try pressing and holding down the "ins" or "insert" key while powering on the PC.
Hope this helps.
No audio from speakers--- Abit NF-7 v2.0 MOBO----
Same configuration? (Same: Mobo, Processor, Hard Drive?) Just new case and cables? Do you have onboard sound, are you running a sound card, or perhaps you're plugged into a fancy graphics card sound port?. Try these configuration tips before you tear it all apart: Check your device manager in the system section and make sure your intended sound device is operational with no (!), or (?) alerts next to it. Reinstall any mobo, graphics card, or sound card drivers which run your sound device. AND finally, if you have more than one sound device on your computer (mine has all 3 options I described), make SURE you have the right one selected in your sound manager!
Jan 13, 2009 | Abit NF7 Motherboard
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
EliteGroup ECS GeForce6100SM-M
Did you use the on board video? Try to repalced the video card.
Feb 23, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
I have a blank screen
so are you asking if there something wrong with your mobo?
if yes, try checking for the jumpers.
Jan 14, 2008 | ASUS P5N32-SLI Deluxe Motherboard
Soyo Slot 1 SY-6BE+ Motherboard Logo
56 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
