I have a Acer 1355LC. When i turned it on, the screen failed to light up. All connections seemed ok.What do i need to do? bruce
    Genius:
  • 1,478 Answers
Does the system power on, just the screen that fails to lighten? if yes, the problem should be from the screen back light. The back light must have gotten burnt and needs to be replaced for your screen to brighten up again.
Take care.
Posted on Jul 21, 2010
Rockola download jukebox lights and screen do not turn on, but "insides" seem to be running ok. Screen says no video connection, then goes blank. Video cables are ok.
The lights inside most likely indicate it has power and is waiting for power button to be pressed. Could be as simple as power switch is failing.
Feb 23, 2015 | Computers & Internet
I have a acer aspire 5720 and I went to turn it on and it turns on but nothing at all comes on the screen
If the fan runs and the keyboard lights up with hard drive noises, the screen is probably faulty. Shine a bright light at the screen, that will tell you if the inverter has failed or not as if you can see something in the background, the screen is OK it is the inverter.
Nov 08, 2013 | Acer Aspire Computers & Internet
I want to locate cmos battery in my Acer aspire 1355LC
The battery of a laptop is always situated at the rear side, just below the screen, when you keep the screen vertical. Or else, it is situated very close to the charging port of your lap. It may be locked by simple switches. You will understand it's operation on looking into them.
Hope this one solved your problem. If you have additional doubts, please come back to us.
P.S: If the solution is helpful, please accept the solution.
Regards,
Sunny.
Sep 01, 2011 | Acer Aspire 1355LC Notebook
Hi, I have a problem with overheating (I think) acer aspire 1355lc notebook.... I have replaced the fan, HDD, and thermal paste, but it shuts down completely bang after just a minute.... what to replace...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | Acer Aspire 1355LC Notebook
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
Not connecting to internet yet, network connection fine
Open a browser window and don't worry that it won't connect to the internet. Look at the top right of the window and click on the "Tool" drop down menu. Scroll to the bottom and click on "internet Options". Now, click on the "Connections" tab. At the bottom of the window, click on the LAN settings button. When this window opens, make sure that only the top box is checked. This box says "automatically detect settings". Make sure all other boxes are UN-checked. Click ok and refresh the browser window and see if you can connect now.
Jul 17, 2010 | Acer Aspire 1355LC Notebook
Acer 5634 laptop screen occasionally turns pink!
You have broken wire that connect screen to the motherboard, when moving screen it connect somtime and sometimes disconnect. It about 18pin wire but only one is broken.
Jan 12, 2009 | Acer Aspire 5630 Notebook
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
