Question about Biostar M7VKD Motherboard
COMPATIBLE PROCESSOR FOR Biostar_M7VKD/ - Biostar M7VKD Motherboard
  • 75 Answers
Compatible Processors: AMD Duron, AMD Athlon
you read more about your motherboard you can check the following link
http://www3.dealtime.com/xPO-Biostar-Socket-A-M7VKD
Posted on Jul 21, 2010
Need bios update for amd dual core 3.2 or phenom 9600
Hello here is the homepage:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#cpu
Only the cpu on the list, will fit the mainboard.
Others will be not be compatible with the mainboard, and a bios upgrade will not help with that.
Good luck
Feb 07, 2013 | Biostar N68S+ Motherboard w AMD Phenom X3...
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    When i try to boot my tower it has a bios rom checksum error come up and it freezes. i have tried replacing the cmos battery but the same thing happens. it even freezes up in cmos. the motherboard is a...
    Could be lots of things. First check you power supply, then memory. See if any of the components are getting very hot (be careful not to burn yourself). From there it will be kinda hit and miss till you find what is wrong. May be easier to look for a compatible motherboard on ebay.
    Jim
    May 01, 2011 | Computers & Internet
    I have a biostar board A740G M2L, I want to know if the sempron processor will work?
    Hello
    A740G M2L+
    Click here this is the specification sheet for your Mainboard.
    Yes, Sempron AM2/AM3 processor will work.
    Best of luck building your PC it is very exciting.
    Oct 24, 2010 | AMD Computers & Internet
    I've a Biostar M7VKD m/board and I want to increase its memory to 1GB. I has 128MB at the moment. I've looked up some details and the advice is to fit 128 or 256 not 512MB.
    The maximum amount of memory you can use is 768MB (3 x 256MB). It's not possible to go any higher. The reason to that is because it's using SDRAM DIMM, and SDRAM generally goes up to 256MB. So, even if you wanted to, you probably can't find any 512MB of SDRAM.
    Mar 09, 2010 | Biostar Computers & Internet
    Looking for compatible processor for biostar P4M800 M7A mainboard
    Hi there.
    Your board is a socket 775, also called Socket T or LGA775, is a Land Grid Array (LGA) socket used for the most recent generations of desktop Intel microprocessors starting from Pentium 4 and up to Core 2 Quad / Core 2 Extreme families. The socket LGA775 supports Intel CPUs from 1.8 to 3.8 GHz with Front-Side Bus frequencies ranging from 533 MHz to 1600 MHz.
    Its up to you which type of processor you get but now you have the general idea.
    Good luck and thanks for using FixYa!!
    Mar 05, 2009 | Biostar P4M800-M7A Motherboard
    Mother board reset buttom?
    I assume you have the fan of your power supply working indicating that power is OK.
    Disconnect everything from the motherboard leaving only the processor, fan and power. If you don't hear any beep means that you have a problem with either the motherboard or the processor.
    PS Verify compatibility of motherboard FSB and processor.
    Oct 19, 2007 | Biostar computers10: Main Board...
    Biostar M7VKD Motherboard Logo
    Top Biostar Computers & Internet Experts
    Jayburt
    David
    David
    Jerry Umali
    Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
