Question about Acer X193W LCD Monitor
How do you change the contrasting on the acer monitor x193W
  • 426 Answers
Check for hidden buttons around the ridge and on the back if none are found you will need the software from acer to manage the display settings
Posted on Jul 21, 2010
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
How do I change the contrast on my monitor Acer x193w
mcdevito75 here, Press the AUTO button on the monitor under to lower edge of monitor itself. This restores factory settings, if you still want to adjust, press MENU button then use left / right arrows to adjust picture quality.
Jul 19, 2010 | Acer V193w LCD Monitor
Acer X193W not getting any signal when connected to 8600GT by DVI
If you know the cable and the place it was before
replace it and reboot the dude (Ps if you dont have the referce and instructions for the take a polaroid
Oct 19, 2009 | Acer X193W LCD Monitor
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Jul 14, 2009 | Acer X193W LCD Monitor
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
How to adjust intensity of Acer X193W LCD monitor manually
if you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Mar 06, 2009 | Acer X193W LCD Monitor
Crnt get no sound x193w lcd
As far as I know the Acer x193w monitor does not have speakers. In order for you to have sound you must attach speakers to the sound card at the rear of the computer. Usually indicated by a light green colored port.
Dec 20, 2008 | Acer X193W LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
How can I change the brightness & resolution on my NEW acer x193w monitor? The instruction booklett is verv unspecific! I am alsi finding that certain programmes are responding a lot slower than ever...
basically its work on a resolution of 1440x900 install drivers for lcd monitor and set the brightness and contrast in display properties(advanced) again same problem post clearly the problem
Mar 11, 2008 | Computers & Internet
Acer X193W LCD Monitor Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
