Question about Toshiba P000223420 - SOUND BOARD, FVRSD5
Sound card problem
Sound is not coming
    Scholar:
  • 32 Answers
Hi
heare is full solution of sound and sound card....
First, test your speakers by connecting them to another sound device like CD/DVD player or a similar device. If you can hear sounds from the speakers, they are fine. Next, connect the speakers back to the computer. Make sure that you plug them into the right colored jack at the back. The speaker pin should be plugged into the green jack at the back of the computer.
Now, if you can't see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click "Sound and Audio Devices" and check the box that says "Place volume icon in the taskbar.
Next, run the following command from the Start -> Run box and then press Enter: dxdiag
Click on the Sound tab and you can see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card driver, on paper. If you can't even see the sound driver name, the driver is not installed or not installed properly.
The easiest thing that you can do now is to do a system restore, using the System Restore utility.
Here's a link about how to use the system restore utility on Windows XP:
http://www.microsoft.com/windowsxp/using…
Here's a link about how to use system restore from Windows Vista:
http://www.howtogeek.com/howto/windows-v…
If System Restore didn't make the sound work, do the following:
Start the Device Manager (Right-click My Computer -> Properties -> Hardware -> Device Manager) In Device Manager, Click the + sign next to "Sound, video and game controllers". See that the sound driver that you noted above, is listed.
Now, double click the item in that list that has the same name as you saw in dxdiag's sound tab. Does Device Manager say that the device is working properly? If Device Manager says that the audio device is not working properly, or if there is a yellow exclamation mark next to the device, or if it says that the drivers are not installed for this device, install the drivers from the CDs or from the computer manufacturer's website. However, there's an easier way to do this, as given below.
Here's the easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which scans the computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free tool from here: http://xpdrivers.com/index.cfm
or directly from this link: http://xpdrivers.com/download/download.c…
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
It's also possible that the drivers are there but the sound card was displaced a bit from it's slot (in case you have a separate sound card on your motherboard, and not a built-in one).
If you suspect this, you should open up the computer and pull out the card. Then, re-insert it firmly into the slot or try another slot if you have another one free. Make sure to tighten the screw to fix the card to the case, and put one there, if it's missing. Here's a youtube video about how to install a sound card:
http://www.youtube.com/watch?v=wp4TDe814…
If none of the above methods worked, pull out your sound card and test it in another computer. You can also try re-installing Windows and lastly try another sound card, if it still fails to work.
Posted on Jul 21, 2010
Sound coming in and out
In most cases, a replacement as card basis will be really good. To get more details, http://electronicshelponline.blogspot.com/ To buy its genuine sound card, contact the authorizes service center for Panasonic.
Nov 28, 2013 | Televison & Video
Creative sound card 4870 DRIVER WIN 7
The driver should come with the sound card when you purchased it. It should come with a DVD that contains the sound card driver. You can also look for the driver in the website of the sound card manufacturer.
After installing the driver, Make sure to keep it updated so that you can avoid from any issues. You can use RadarSync to automate the updating process in your computer.
David
Apr 19, 2013 | Creative Labs CT4870 / CT4780 Sound Card
When on skype this message comes up Can't access your sound card skype needs to access your computer sound card to make calls
check your sound drivers from device manager, if not installed, then install updated drivers of your soud device and then it will not show any problem
Jan 11, 2013 | Computers & Internet
I recently purchased a new M-Audio Audiophile 192 sound card but I cannot get it to work, I don't hear anything coming from my speakers (M-Audio AV40s), which I know are working because I tested them...
This could be that the Onboard Sound Card is turn on in the Basic Input Output Settings, these control wich devices start and run when you computer is first turned on. Commonly known as the BIOS there very often is a setting in there for the sound to come from the onboard sound card or the one installed seperately. You must access this setting when you first sstart your computer, and switch it to disable onboard sound.
Sep 16, 2011 | M-Audio Audiophile 192 Sound Card
9200 lx laptops sound not coming
Did you install the audio drivers that comes with the hardware?!
There should be a cd installer comes with the sound card.. it is the driver that you need to install for the sound card to work...
Feb 18, 2011 | Creative Labs Sound Blaster Live! 5.1...
Why do I need a sound card for my laptop pc?
Hi. Sound card is a device inside your computer that is responsible for the sound coming out to your computer. Without the sound card there will be no sound comes out to the laptop.
Oct 09, 2010 | Computers & Internet
No sound coming out of speakers
maybe your sound card is defective,buy a new one
Feb 07, 2010 | Acer (54.AA806.001) Sound Card
Sound is not coming even after installing drivers
please solve this problem and where to download this audio card Close expert_editor_close.png
May 12, 2009 | Intel ESS ES1868F Sound Card
EMU 1616M sound card
I know this is a longshot, so forgive me..
Hit F8 on booting up and go into the BIOS, and use the arrow keys to navigate to sound and check that the PCI (sound card) is checked and not the OS (onboard sound). Save to CMOS and Exit.
I know.. I know.. but sometimes it's as simple as that..
Let me know how you get on..
Chris (ziraffa)
Dec 29, 2008 | E-Mu 1616M Sound Card
MY SOUND CARD SOUND LIKE
check device manager for your sound card, and tell me what it is. also, your software your sound card uses.
most sound changes comes from the software.
Nov 15, 2007 | Acer (54.AA806.001) Sound Card
Computers & Internet Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
