How to close installshield ? i want install software,but in the middle set up come some error,ask for close installsheild that the problem. quickuse
    Sergeant:
  • 269 Answers
Follow this link and reinstall insallshield follow all the steps you should be ok
http://consumerdocs.installshield.com/selfservice/viewContent.do?externalId=Q108322&sliceId=1
Posted on Jul 21, 2010
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
Error 1607 unable to install InstallShield
how you fix it
Reinstall the InstallScript engine loadTOCNode(2, 'resolution'); To reinstall the InstallScript engine from InstallShield Developer, follow these steps:
  1. Download the ISScript7.zip file. To do this, visit the following InstallShield Web site: http://consumer.installshield.com/kb.asp?id=Q108322 (http://consumer.installshield.com/kb.asp?id=Q108322)
  2. Extract the ISScript7.zip file.
  3. Double-click the ISScript.msi file.
Running Setup from a virtual drive loadTOCNode(2, 'resolution'); If you are running the Setup program from a virtual drive created by using the SUBST command, you can delete the virtual drive and instead run the Setup program from the physical hard disk. To delete the virtual drive, click Start, click Run, type subst drive_letter: /d, and then click OK.
good luck
Mel
Jun 05, 2010 | Microsoft Windows Vista Home Basic for PC
I just installed windows XP service pack 3, installshield errors
Hi, "I hope this will help you out with the problem! Try this Link: http://www.technospot.net/blogs/download-directx-10-for-windows-xp-from-alky-project/ "If this help? Feedback is appreciated, thanks paul7of9."
Feb 04, 2010 | InstallShield Update Service Version 3
I am having no luck installing Spongebob typing on Windows XP
Seems i had this problem with another spongebob game.
Try downloading and installing installsheild.
here is a link to it.http://software.informer.com/getfree-installshield-wizard-vista/
Uninstall game files before you install install sheild
You may also want to run windows update for a more updated version of xp
Thanks
Jan 22, 2010 | Encore SpongeBob SquarePants Typing...
My BB pearl 8110 keeps rebooting on its own.
  1. Right-click the Windows Taskbar.
  2. Select Task Manager.
  3. Select windows installer from the Applications tab.
  4. Click End Task.
  5. Perform a clean uninstall of the BlackBerry Desktop Software.
  6. Reboot the computer.
  7. Reinstall the BlackBerry Desktop Software.
Follow the trouble shooting steps for uninstall of the BlackBerry Desktop Software.
Task 1: Uninstall BlackBerry Desktop Software
For Windows 98/ME/2000/XP
  1. Close BlackBerry® Desktop Manager, if it is running.
  2. Open the Control Panel and double-click Add or Remove Programs.
  3. Select BlackBerry Desktop Software and click Change/Remove.
  4. On the InstallShield® Wizard window, select the Remove option and click Next.
  5. On the Uninstall Options window, select the check box labeled Remove all user settings for BlackBerry Desktop Software.
  6. On the Confirm Uninstall window, click OK.
  7. On the InstallShield Wizard window, click Finish.
Task 2: Uninstall BlackBerry Desktop Software
For Windows Vista®
  1. Close BlackBerry Desktop Manager, if it is running.
  2. Open the Control Panel and click Programs and Features.
  3. Select Uninstall a program.
  4. Select BlackBerry Desktop Software and click Change/Remove.
  5. On the InstallShield Wizard window, select the Remove option and click Next.
  6. On the Uninstall Options window, select the check box labeled Remove all user settings for BlackBerry Desktop Software.
  7. On the Confirm Uninstall window, click OK.
  8. On the InstallShield Wizard window, click Finish.
Oct 26, 2009 | RIM BlackBerry Pearl 8100
Installshield 3 Help (maybe)
I didn't get a solution but the project was dropped. I don't have to do this install.
Sep 19, 2008 | InstallShield Update Service Version 3
Get it for free
could you give me more info plz
May 22, 2008 | InstallShield 10.5 Premier...
Try to install D-LINK DWL G630, get error 1607, windows xp
Error 1607 appears while trying to install the product. The installer is unable to invoke "InstallShield", a third-party utility used to perform the installation.
Step 1
  1. Select Start, Run, and type REGEDT32. Click OK.
  2. Browse to the following key:
    HKEY_LOCAL_MACHINE\SOFTWARE\InstallShield
  3. Check the permissions on this key:
    Windows XP: right click and select "Permissions"
    Windows 2000/NT: navigate to the "Security" menu and then select "Permissions"
  4. If not already assigned, assign "Full Control" to the following groups:
    a. Administrators
    b. SYSTEM
  5. Reboot the computer
  6. Try the installation again
Step 2
If step 1 did not correct the problem, please see this article on the InstallShield web site.
HERE is a link to the Microsoft Knowledge database that may be of help as well. (ALthough it mentions its for games, it should work with any software)
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 19, 2008 | Computers & Internet
Desktop Software Will Not Load!
The problem that you are encountering right now is a windows problem. "idriver.exe" is related to the installshield application on your computer and installshield is used to install application on your computer, so if idriver is not working, installshield will not work also. I suggest try the windows update. It might fix the problem.
Sep 11, 2005 | Palm Tungsten E Handheld
Error Containing "0x123454" when installing software
Any error code beginning with "0x" is related to a problem with incompatibilities with the InstallShield program which is used to install all of the components. To fix this find the "InstallShield" folder on the computer (the location varies by computer OS, but is generally located in "c:\Program Files\Common Files\") and move the contents to a new folder on the desktop of the compter. If everything works well you can discard the new folder (and the old InstallShield contents). Run the Nikon installer again and it will install properly.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
