Question about Gaggia Titanium Espresso Machine
Ventilate button does not seem to work
Hi. when the "ventilate" message appears, the hot water button does not seem to work. further, no steam comes out. we tried manually priming the circuit, but that has failed as well. any help would be greatly appreciated.
  • 515 Answers
If you open the steam knob, can you get out any water?
Posted on Jul 13, 2008
Afraid not. fortunately, it was still under warranty and it was eventually determined the problem was due to a faulty steam valve. things have been trouble-free since then. i hope others may benefit from this experience. thank you for your response.
Posted on Jul 25, 2008
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
What does ventilate mean?
"Ventilate" simply means that there is an air pocket caught in the system and running water through it can fix the problem. When the ventilate message appears, you will need to run hot water through your steam/hot water wand as if you were going to fill your cup with hot water. If the message does not go away after doing so, you will have to run hot water through your wand continuously into an empty container (emptying one full water reservoir if not more). Once your display screen reads "Select Product, ready for use," you will be ready to brew delicious coffee again.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | Gaggia Syncrony Compact Digital Espresso...
Ventilate message, then no steam coming out
Sounds like you have an internal blockage in one of the boilers.
Take it to your local service agent for repair.
Did you remove the milk frother and try the hot water again?
A blocked frother is a very common problem .
Feb 24, 2010 | Gaggia Titanium Espresso Machine
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
'Ventilate' message with functional direct water supply
Hi You need to push the button with the drop under it. That will turn the water on. The dial is just for steam.
Jan 30, 2010 | Saeco Royal Professional Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
Ventialtion error
It´s probably the flow meter in the machine you have to replace, it´s like a water counter, if it not reach the right value then it not reset the ventilate sign.
Make sure to descale your machine regularly, the calcium is a very big problem for the machine.
May 17, 2008 | Gaggia Titanium Espresso Machine
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
328 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
