Question about Zanussi TC7102W Electric Dryer
I have a Zanussi ZDE26100W electrolux dryer it is turning but not heating up what do i need to do thanks
2 Suggested Answers
  • 3074 Answers
SOURCE: i have zanussi electrolux zde26100w
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Posted on Mar 13, 2011
Zwd14581w - both washer/tumble not getting warm
Possibly the heating element is enclosed by chalc buildup. The heat is still built up, but isolated from the washing water by chalc. Loopup methods to clean the washer or ask a professional.
Dec 17, 2013 | Electrolux Zwd14581w Zanussi Washer/Dryer...
Zanussi electrolux dryer not coming on
Possible that there is no supply to the motor in the dryer mode.
Please check the motor and the program control using a meter.click for tips on this link: washing machine tips
Jun 25, 2012 | Zanussi Washing Machines
No heat drum turns on td4212w
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 28, 2010 | Zanussi TD4112W Electric Dryer
I have a Zanussi Electrolux ZSF6126 and the
Check to see if the heat element in the bottom inside is all crusty or cracked, if so replace, if not, unplug unit from house current, pull bottom toe panel off, you should see where heat element comes thru cabinet and has two wires attached, remove wires, take ohm meter and check for reading, if reading is ok then you either have bad control timer circuit (main board) or blown thermal fuse. Call tech to check further if you do not have original tech sheet or electrical background. My bet is that you have a bad heat element.
Nov 12, 2009 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi tumbledrier TC7103W not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Aug 30, 2009 | Zanussi TC7114W Electric Dryer
Zanussi tc 481w codenser dryer
this is possibly the belt slipping remove back panel and check the belt tention if not that it could be the bearing needs replacing
Aug 16, 2009 | Zanussi TC7114W Electric Dryer
I am constantly getting a E10 error on my Zanussi w1042w. what could be causing this?
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 14, 2009 | Washing Machines
Zanussi TC7102W Electric Dryer Logo
200 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
