Question about Brother P-Touch 1180 Label Printer
Not printing error symbol looks like the rollers are'nt activating
Won't print just gives an error message
Posted on Aug 03, 2010
13.01.00 jam in tray ... error message
Most likely worn pickup/feed roller. Remove the roller and clean it. Many HP rollers you can rotate the rubber for a quick fix.
Jul 14, 2016 | HP LaserJet 2300 Printer
When i turn the photocopier minolta di 470 on the table displays normally after a moment the photocopier turns off and displays the code c1334 i would like to now the meaning of the code.
C - 1334 Duplex take up print command error.
A duplex take up print command is not received for the paper to be taken up from the duplex after the papers has moved past the horizontal transport but before it reaches the transport roller.
The number of duplex take up print commands falls short of the number of sheets of paper to be taken up from the duplex or the leading edge of the sheet of paper,for wich a duplex take up print command is yet to be received activates the transport roller sensor.
Clean the transport feed rollers and the sensors.Reset the error code using the trouble reset switch and open/close the front door.
Apr 09, 2013 | Konica Minolta Office Equipment & Supplies
Symbol lit up but don't know what symbol means, I don't have manuel - begins with 2 dots :
The symbol with the 2 dots and what looks like a jagged line is the paper jam indicator. Open the paper tray and or front and back access doors to find and remove the paper jam. I the light still does not clear try turning the printer off then on to reset the jam indication.
Aug 20, 2010 | Lexmark E260 Laser Printer
I hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any...
i hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any solution so dat i may nt loss my data and free. inf me on y email shin_dragon_pke@yahoo.com help is need ASAP
Jul 02, 2010 | Computers & Internet
Dump file error, pc freezes
I would do a complete reinstall. It looks like you have really upset your pc. The kernal files are part of the main operating system and when they mess up its not good. As I said I would redo the pc..Sorry to say you will lose all personal files on pc..
Nov 17, 2009 | Lenovo 3000 N200 Notebook - Intel Celeron...
Service error 6A00
It looks like the print carriage was stuck. Turn on off the printer, manually move the ink cartridge back and forth a few times, look underneath for dirt or small piece of paper (usually happens when you have jammed paper) or use a blower to clean any foreign objects.
Apr 27, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Red light flashing, And little cartridge symbol on printer screen,
Check the ink levels, and that there is not a paper jam.
if nothing of those two, try uninstalling and re-installing printer drivers. sometimes you can unplug the printer for 20-30 minutes. which may enable it to reset to it,s default settings. if this does,nt help. refer to the user manual.
good luck Mike @ Compurepair.
Feb 20, 2008 | Office Equipment & Supplies
Paper feed problem, then error
SEPARATION ROLLER MAY NOT INGAGE CAUSING THE PAPER NOT TO FEED TO THE FEED ROLLERS THE PAPER DOES NT ADVANCETO THE REGISTION ROLLER THAT SET THE PAPER FO COPY CHECK TO SEE IF THEY ARE CLEAN OR WORN
Dec 07, 2007 | Konica Minolta magicolor 2400 Laser...
Brother P-Touch 1180 Label Printer Logo
155 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
