Cant understand how it works and how to copy my files onto the external drive!
  • 150 Answers
Please be more specific,
Posted on Apr 22, 2008
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
I cannot put files on my external hard drive
just plug your hard drive in another noze of usb...
if u have loose connection in usb then it will happen. try to copy small size of data
Sep 01, 2012 | Western Digital My Book Essential 1TB...
Bought Punch Home & Landscape Design Premium at Best Buy. Cannot load software from disk. Comes up with error 1305 cannot read tool7501.mp4 verify that file exists and you can access it?????
I had the same problem. I copied the files from the disk onto an external hard drive. Double-clicked the setup file that I copied and installed the program from my external hard drive rather than my cd drive. It works great! Recommend copying ALL files to a hard drive and installing that way.
Sep 09, 2011 | Punch Home & Land Design Nexgen for PC
My Hard drive has only 6% space left on it.Can i connect external Hard drive to it?
> can I connect an external hard-drive to it?
However, an external hard-drive should _ONLY_ be used to make an _ADDITIONAL_ copy of your important files. It should _NOT_ be used to store the _ONLY_ copy of some files -- if/when the drive fails, the _ONLY_ copy of those files will be _GONE_. Not good!
Instead, it's time to purchase an additional "internal" disk-drive, which will be _NEWER_ and _LARGER_ and _WARRANTIED_ and to use software to "clone" your old hard-drive onto your new hard-drive.
Then, disconnect the old, out-of-warranty, disk-drive, and boot Windows from the new disk-drive.
Then, purchase an EMPTY disk-drive enclosure, for about $30,
install your old disk-drive into the enclosure, to build your own external storage device. Once you're satisfied that your new "clone" disk-drive is working 100% correctly, delete all the files from the OLD disk-drive, and then make a backup of your files onto the now-empty disk-drive.
Oct 30, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Toshiba A 45-S150: How to boot from external dvd drive?
Remove the disk-drive from the laptop, and connect it to another computer.
Copy all the files from the recovery-media onto the disk-drive.
Reinstall the disk-drive into your laptop.
Run the recovery software from where you copied the files onto the disk-drive.
Jan 01, 2010 | Toshiba Satellite A45-S150 Notebook
Drive will not copy files to it
The Macintosh OS may not work with the drive due to the file system on the drive was created with windows. The drive may have to be re-formatted with the Mac to work on it. Now I don't use a Mac so I assuming the OS will have a problem with FAT32 or NTFS format that windows uses....I could be wrong.
Sep 10, 2009 | Western Digital imicro IM35ST320SI 3.5 IDE...
Want to use clone hard drive to run XP
Because the HP and Fujitsu have different devices, you cannot clone (or create an image of) the hard disk and expect it to work on the other laptop.
Your best bet would be to copy your data files onto a USB memory stick or an external USB hard drive and plug it into the HP. You can open the files on the USB memory Stick/hard drive to work on them or copy them to the HP's hard drive to work on them.
When your Fujitsu has been repaired you can copy the latest files from the USB memory stick/hard drive back onto your Fujitsu.
Jun 19, 2009 | Fujitsu LifeBook S7010D Notebook
My ps3 isn't loading games
ok, first, copy your save files onto a flash drive or external hard drive. you can either copy an paste your files, or, if you have an external, you can go to backup utility in the settings. If you dont care about your non-online saves and install datas(you can always re-install), you can just skip that part and just go to settings, system settings, and go to format utility. follow the on screen steps and format your internal hard drive. when done, if you copied your files, you can go to system settings and transfer the files back. If this doesnt work then you will have to get a new ps3, but my friend had the same problem, and reformatting his ps3 fixed it.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Need to transfer copied files to x301 after full restore
create a new folder in your hard-disk and first try to copy 1-2 files from the external hard-drive to the new folder (copy any data/work/images you have stored/created not any files of windows folder or root of c: drive)
if the above copy works then copy back all except the c: root and these folders - Windows folder, Document & settings, Program Files
May 30, 2009 | Lenovo ThinkPad X301 2776 Notebook
Computers & Internet Logo
David Payne
David Payne
