Hi there, i have a k800i when i changed the CIM the phone newer switched on., a red light blinks through the IR port when i try to swith on, i took to a place to pu the software, they said the phone is not ditecting, and they cant repair it, what can i do for this, pls advice
Comments:
Apr 24, 2008
- thank you so much i will try it and let you know, thanks agian for your time
May 13, 2008
- Hi Grabmob,
I found the solution
thank you again for trying to help me, i did what you said and it didnt work, then i went to so many service centres they also could not do this, i went to sony ericsson service centre, they also said if its under warranty they will replace a new phone cos they cant repair it,
at the sony ericcson service centre a person said he can make it and he did it within an hour at his residence, he is having a small repair centre and he does any mobile phone problems, he removed the phone and took the mother board and wrote the software i gues, but when i tried with somany software the phone newer ditected, it just cost me 20 US dollars
we will approach the problem this way
1) your battery might be the culprit , first charge your battery in a different piece, and then replace ans see.
2) if the above doesnt solve the problem clean the connectors of the battery that shiny golden part of both your battery and mobile piece , with nail p[olish remover or alcohol.
3) last resort now will have to open the piece and check for the on/off switch .
4)lastly software reflashing, but if the piece aint dtecting, need to clean the datacable connectors with nail polish remover or alcohol.
the above should bring your pice to life.
Was this helpful?
Yes
No
Solution #2
posted on Sep 29, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hiii Dis Is Rahul N My Phone ( K 800i ) Is Not Geting On N People Said Its A Software prob N Till Naw It Dint Got On Plzz Help Me Out In Dis
Popular Solutions for Sony Ericsson K800i Cellular
hey guys im new to fixya and i have a problem with my sony ericcson k800i on the network 3. i...
(More)
hey guys im new to fixya and i have a problem with my sony ericcson k800i on the network 3. i recently master reset the settings and after that i cant call people get called get onto the internet or even sign on to msn? Also my bluetooth, when i turn my bluetooth on it says bluetooth on but it doesnt actually turn on? thanks
The actual display is positioned off the top of the screen, with the buttons usually found at the...
(More)
The actual display is positioned off the top of the screen, with the buttons usually found at the bottom of the screen the only thing visible at the top of the screen - the rest of the screen is white
New Sony Ericsson W595 Worked perfectly for 3 days When turned on kepad lights up but screen remains...
(More)
New Sony Ericsson W595 Worked perfectly for 3 days When turned on kepad lights up but screen remains blank
