Question about Denon AVR-3300 Receiver
Avr 3300 many thanks for that, i was playing with the amp last night and unplugged it from the mains, i left it for about 10 mins, plugged it back in and it worked fine. i suspect it gave it enough chance to cool down?. i will find my local denon dealer and get them sort it out,as it is a shame to just throw it away if it can be fixed.
    Scholar:
  • 54 Answers
Sounds right. Yes it is a shame because it is one of the nicest sounding home theatre receivers. Especially in good old 2 ch stereo. Which is a true test of the basic design of an amplifier. If it sounds good after you strip away all the bells and whistles, then you have a nice house on a solid foundation. Otherwise you have a nice house built on sand. ....good luck and I know the dealer can sort it out properly. ....Rob
Posted on Apr 22, 2008
Help! no sound on my tv!
check all the leads and wires, especially the scart lead, and give them a little push, if this doesnt work (which it should) then unplug the tv from the mains, wait 5 mins, plug back in, wait another 5 mins, and turn on, if this still doesnt work, contact the customer service line of the company who made your tv
Mar 17, 2012 | Sharp Televison & Video
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
Protection error in denon avr-3000
Do you know what caused the protection shut down in the first place? Did you short your speaker wires even briefly?
You could try to Unplug the Unit for Few Minutes, say 30 minutes and then turn it back ON.Usually that would fix the issue.
If you are going into protect mode with no speaker attached,chances are that your output Ic is in need of replacement .This is the most likely cause of a protection error that you are experiencing.I am having a bit of difficulty in locating specific part numbers but feel confident that replacing outputs will remedy your concern.For further info and parts or authorized service locations in your area I suggest to contact mfg at www.usa.denon.com/ .Click on support or call(201)762-6500.I believe that they have a flat rate service and will give you an estimate.
Still, on the remote possibility that it is just a glitch caused by momentary power interruption or fluctuation, try to re-initialize the microprocessor, a hard reset (not unless this is what you were referring to as rebooted). The reset should force the AVR-3300 to revert back to factory defaults removing glitches, errors in settings & configurations, memory & presets as well as user preferences.
* turn OFF the unit using the POWER button;
* press and hold both SPEAKER A and SPEAKER B;
* without releasing the 2 buttons, press the POWER button;
* release the 2 buttons only when the display starts to flash;
* in the event of no display flashing, repeat the process.
Should the above be not corrective, then it would be a hardware fault and not just a glitch.
Let me know, if needed further assistance.
Hoe i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 13, 2010 | Denon AVR-3300 Receiver
No sound from Sub.... from my Denon AVR-2700, not AVR-3300, Yeah its old!
if the subwoofer is on in the reciecer settings then maybe the amp is not getting the signal or the amp is not amplifying
try unplugging the output of the sub then turn off the reciever for a min. then turn it on wait , then plug the sub in
if that don't work then test the sub output with a stereo that has a audio input
also test the subwoofer with a audio output to it( only a positive and a negitive wire for sub)
Oct 26, 2008 | Denon AVR-3300 Receiver
Moxi DVR
You will probably want to get the audio module checked by a professional. It could be something as simply as a blown capacitor/resistor, but if you are not familiar with this, best get a professional to diagnose/repair the set.
Try this first:
Unplug the tv from the mains and remove all cables. Wait for about 10 mins. Now plug the TV back into the mains, while holding the power button ON. See if this resolves the issue.
I would also recommend investing in a surge protector/spike buster if have frequent storms in your area.
May 11, 2008 | Televison & Video
Wii console will not come on
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Apr 09, 2008 | Nintendo Wii Console
AVR 2807 shuts off at high volumes
You may have leaky Caps in the power supply or else dry joints on the amplifier section. Faulty speakers or overdriving of the system may result in the amp going into protection. Good Luck, Jus004
Jan 05, 2008 | Denon AVR-2807 Receiver
Denon AVR-3300 Receiver Logo
116 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
