Model # LAT2500AAE Agitator will not turn and will not spin. Smell rubber last knight?
jsrock516
  • 5911 Answers
SOURCE: topload washer agitator does not move
Sounds like you've already replaced your lid switch and now the washer stopped agitating and spinning, but WILL still drain water. If I'm understanding these symptoms correctly, these are common symptoms of a broken motor coupling. The burning rubber smell is another symptom as the coupler has a rubber bushing that can tears apart when the coupler breaks. There may also be a strange rattling noise associated with these symptoms too. The coupling is located between the drive motor and gearcase (transmission) and this is what transfers the energy from the drive motor to drive the transmission, which makes the drum spin and agitate. It is common for this coupling to wear out, strip, or break over a period of time. This is a very inexpensive replacement part (usually $15 or less) and can be replaced easily by the average do-it-yourselfer with a little guidance. The following link gives you step-by-step instructions how:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Some of the orginal motor couplings that came from the manufacturer were totally made of plastic. Over a period of time (especially with heavy loads) the center shaft on the coupling would strip out and the coupler would free spin. The manufacturer came out with a new improved, longer life coupling with a steel grommet. The link provides you with the new part number and where you can order the part if you wish go online. If you do not wish to order from the website, take the part number provided and go to your nearest appliance parts retailer. This is a common part they carry. I hope this helps you. If you require addtional assistance, please contact me and let me know.
Posted on Aug 30, 2008
  • 39 Answers
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Posted on Sep 16, 2008
csmock132
  • 4669 Answers
SOURCE: Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Posted on Feb 28, 2009
JULIANFIX
  • 975 Answers
SOURCE: Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
Posted on May 18, 2009
kvhappliance
  • 218 Answers
SOURCE: I have a Maytag performa Model PAV2200AWW. Today
You most like have a bad motor.
Posted on Mar 17, 2010
Smoke come in out while spinning
Don't know what machine you have if it has a belt check it. Take belt off & see the motor turns freely also with the belt off see if you can turn the drum if one of them won't turn the belt will slip & cause burning smell. Small clothes getting under the agitator even sometimes in the pump can cause this , check under agitator & check the pump it may not turn if a sock or something gets in it & this can cause the belt to slip. If these seem ok put it in spin & watch the motor it could have a short & will smoke. Good luck
hope this helps.
Nov 22, 2017 | Washing Machines
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
Clothes washer tub spins on wash
sounds like u have a problem with the "brain". The agitator and spin cycle should never run at the same time. therefore it leads me to A: brain issue B:problem in the actual transmission of what cycle should be running. You will continue to smell the burning rubber due to the issue being one of the two explained above. Does it ever NOT spin? If this is the case the likely hood is that it will be a solenoid.
Apr 21, 2013 | 2000 Honda Accord
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
My Maytag Performa doesn't work on spin cycle. Burning rubber smell. Belt looks okay. Pumps out rinse water but drum won't spin.
Brakes are locked in the spin cycle or the pinion shaft has dropped down from within the transmission not to engage the agitator.
Nov 05, 2009 | Washing Machines
Vaccum cleaner belt change
If you've put a new belt on and you still are getting a rubber smell, then odds are that your agitator (the rotating brush) is not turning freely, and that means either (a) you need to remove the end caps and remove any hair / debris that is under those end caps, or (2) the bearing(s) of the agitator are bad. Depending on the model of the Sharp (which was not provided), you may be able to order just the defective bearings and replace them (or take the agitator to a vacuum shop to have them do it), or you can (or may need to) order the agitator assembly complete.
May 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
I seem to have a belt slipping maybe. Clothes are not wrung out as they usually are at the end of the cycle and there was a sort of burning rubber smell last time I used it. I looked at the belt under the...
You may have cleared the problem when you cleaned under your agitator. The belt may still need replaced if it was glazed while it was slipping as the burning rubber smell you mention would suggest.
I would give it a light or no load try while standing by and check to see that it agitates, drains and spins ok as you advance the timer to test all functions, and of course turn it off if it acts up.
Good luck, and please update us on your results?
Mar 21, 2008 | Washing Machines
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
