Question about Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop
I need a service manual for a fujitsu-siemens Scaleo 600 desktop pc. Specifically I want to know the exact pins on the motherboard to connect the wires and connectors(4)from the front panel. The motherboard does not appear to identify which connectors fit on which motherboard pins so a ervice manual would be really helpful here.
  • Fujitsu Master
  • 5,660 Answers
According to Fujitsu Service Support, the Scaleo 600 uses a Gigabyte GISXT
mobo. (MOtherBOard)
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
(Actually the Gigabyte GISXT-FS motherboard.
G - 'eye' - SXT)
This is the PDF download, for the Gigabyte GISXT-FS motherboard manual,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
Posted on Jul 21, 2010
  • joecoolvette
    joecoolvette Jul 21, 2010
    Barring that the direct link to the PDF file does not work for you, I will
    detail out the connections for the Front Panel header on the mobo.
    (F_PANEL)
    Orientation of the motherboard:
    Processor to the top, ram memory slots to the right, white PCI slots to the
    bottom, (5 of them)
    The Front Panel header is to the extreme right bottom corner.
    Two columns of pins. The Power LED is right above the Front Panel
    header. (PWR LED)
    (Page 24 in the PDF motherboard manual)
    The pins of the Front Panel header are numbered starting from the
    Bottom, going towards the Top.
    Pins on the Right column starting at the Bottom, going towards the Top,
    1,3,5,7,9,11,13, 15,17,and 19
    Pins on the Left column starting at the Bottom, going towards the Top,
    2,4,6,8,10,12,14,16,18, and 20
    A) Pins 1 and 3 are for the HDD LED. (HarDDrive Actvity Lamp)
    Pin 1 is for the Positive connection. ( + )
    B) Pins 5 and 7 are for the Reset switch, with Pin 7 being the Positive
    connection.
    C) Pins 9, 11, 13, 15, 17, and 19 are shown not to be used.
    Apparently there are No pins 9, 11,13, 15, 17, and 19.
    (NC. No Connection)
    D) Pins 2 and 4 are for the Power On LED. (Also MSG)
    Pin 2 being the Positive connection ( + )
    E) Pins 6 and 8 are for the Power On switch
    Pin 6 being the Positive connection
    F) Pins 10 and 12 are not used . (NC. No Connection)
    G) Pins 14, 16, 18, and 20 are used for the internal speaker.
    Pin 14 being the positive connection
  • joecoolvette
    To add if I may.
    If you do not know, or there is no indication thereof,
    of what the individual cables you have stated go to; you'll have to trace their origin.
    Trace the cable that goes to the Power On switch, behind that Power On button.
    The Power On LED lamp may be in this cable also, or it may not.
    The Reset switch may have it's own cable.
    And so on.
    You may have to remove the Front Panel, in order to trace the origins of these cables.
How to conect led pow cables to scaleo motherboard
I just follow the pins and remember that you connect long ways..
try this might help
Apr 04, 2013 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I can't find a driver for my grafique cart of siemens fujitsu scaleo 600 thank's for help :)
on this page
http://ts.fujitsu.com/support/downloads.html
type scaleo 600 for searh
you will be redirected to drivers download page
Feb 22, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I want to download sound drivers for my fujitsu siemens scaleo 600
on this page
type sclaleo 600 for searh
you will
be redirected
Jan 09, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Fujitsu siemens scaleo 600 desktop just keeps shutting down any ideas
1) Bad Power Supply. Power Supply has a weak voltage power rail.
Electrolytic Capacitors are breaking down inside the Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
The capacitors build up a charge long enough to work briefly, then break down.
2) Electrolytic Capacitors on the motherboard are breaking down. Specifically the one's used in the motherboard Voltage Regulator Circuit.
A) http://www.hardwaresecrets.com/article/616
B) Visually identifying bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
C) Video showing what happens with bad capacitors (Electrolytic) in the motherboard Voltage Regulator Circuit (Starts at 0:04)
http://www.youtube.com/watch?v=KN6_-8fYHo0
Await your further diagnoses.
May 23, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Ich habe keinen Audiotreiber mehr auf meinem Computer Fujitsu Siemens Scaleo 600
The German download page is found here
Fill in the field: Bitte geben Sie die Serien-/Identnummer des Gerätes oder den Produktnamen ein: "Scaleo 600"
Then open Audio, look up in the manual of your Scaleo 600 wich audio
chipset your motherboard has onboard to download the the correct drivers.
Note: Use the Fiujitsu Siemens site with Internet Explorer because it does not work very well with Firefox and next time putt your question here in English, you'll get more help in this way.
Succes.
Jan 08, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Fujitsu Siemens Scaleo 600. No power to processor.
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Oct 06, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Finding the videocard in a Fujitsu Siemens Scaleo 600 PC
firstly check the pci slot where your moniter you plug in it. and change the card.
ramesh
Nov 29, 2008 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Onboard Sound Drivers and Video Controllers
Hi EsteG, found all your drivers for your SCALEO 800, these are also used for the SCALEO 800Si 2410 Silent+. They call it the 800 series, for XP. Click the link below.
http://support.fujitsu-siemens.com/com/support/downloads.html
Because it's the whole 800 series you'll need your manual to pick the correct Audio driver as noted in your manual. To narrow down the ammount of drivers in each area. There should be a sticker on the PC that has the serial No# . Enter that number on this link below. (Siemens Fujitsu) does not make this easy.
If I can be of more service, just ask.
Good Luck & Kind Regards.
Mike
Mar 25, 2008 | Siemens Fujitsu SCALEO 800Si 2410 Silent+...
Fujitsu Siemens SCALEO 600 (FSP:83C005617) PC Desktop Logo
1,734 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
