Computer will not recognise netgear router through ethernet port
  • DHANANJOY ROY May 11, 2010
    which ip you are using in the computer . the ip should match the ip of the netgear router
    Novelist:
  • 150 Answers
1) Make sure that the router is correctly plugged in.
2) Power the router down, wait a few secs and then
turn it back on.
3) Hardware reset the router to factory defaults, there should be
a small hidden button to do this.
4) Check the LED lights on the router, and on the back of the
computer's network card (or connector) to make sure the
router is actually communicating at the physical layer.
Check for a bad cable.
Make sure that you are using the correct CAT cable,
not an uplink cross-over.
5) Open up your WEB browser, and if your home page comes
up, then your done.
6) If not, type the router's default IP address into the
Browser's address line and hit GO button or press return.
Typically this address is: 192.168.1.1, if not, check the
router's manual.
7) If the router's setup page comes up, the router is
communicating and all you need to do is setup
the router's features and settings. (see router manual)
8) If the router's setup page does NOT come up in your web
browser, the router is NOT communicating.
9) Check your network ICON on the task bar if there is one,
does it show full connectivity ?
10) Got to: START --> ALL PROGRAMS --> Accessories -->
Command prompt.
11) In the DOS-like command prompt window, type:
ipconfig /release <Enter>
ipconfig /renew <Enter>
ipconfig/All <Enter>
12) Check the display. it should list all your network settings.
13) You should see the network card's brand name,
Physical MAC address in the form of 6 pairs
of hexadecimal digits (48 bit address)
14) You should see your computer's IP address in the
form 192.168.1. (some number between 2 to 255)
This address should be assigned to your computer by
the router using the DHCP protocol
15) If ANY of the above checks fail, run the network setup
Wizard:
a) go to the control panel
b) double click on NETWORK SETUP WIZARD
c) Select my computer connects to the internet using
another computer or a residential gateway (router)
Choose DHCP, not a static address
This should do the trick
Your computer should now be configured to accept a dynamic
IP address from the router using DHCP
Open your WEB browser, type int the router's default IP address,
login into the router with a default factory password, and
set it up based on the instruction manual, or call the router
manuf's tech support line for help.
Good luck
Martin
P.S.
If your router does not provide DHCP services,
which is very unlikely, you may have to consult your
router manual on how to set up a STATIC IP
address, but I have never come across this
problem with any modern router. The dynamic address
should work.
DHCP stands for Dynamic Host Control Protocol,
whereby your computer sends out a special packet
requesting the assignment of its IP address from the router.
Posted on Apr 22, 2008
3 Suggested Answers
chewy777
  • 65 Answers
SOURCE: I'm trying to connect a
i would just stay with the usb if it works. unless your wanting to use the net card instead?
Posted on Aug 11, 2008
  • 2678 Answers
SOURCE: I have netgear wireless N-300
If you mean phone modem on PC then no. Check connection between pc and router by acessing the webinterface (instuctions in linksys user manual).
If all OK there then contact your ISP.
Posted on Sep 03, 2010
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Can i use a wireless cable modem gateway (netgear) to make my current dsl modem connection wireless.
If your DSL-modem has one Ethernet port, then use an Ethernet cable to connect from that port to the WAN port on your NetGear router. Then, the router will provide both "wired" and "wireless" connections to your computers & devices.
Feb 13, 2011 | Computers & Internet
Howto set up netgear router to my computer?
Turn your cable-modem (or DSL-modem) off.
Turn your computer off.
Unplug one end of the Ethernet cable from the network-port on your computer.
Plug that end into the WAN port on the router.
Take another Ethernet cable, and connect one of the LAN ports on the router to the network-port on your computer.
Turn the cable-modem on.
Turn the router on.
Turn your computer on.
Done -- the 'default' configuration in the NetGear works, 100% of the time.
Sep 26, 2010 | Computers & Internet
I8 only have 1 ethernet commector and need 2 had I know this i wouldn't have bought it in thr git=rst place!!!
You can add more ethernet ports by purchasing a 4 port hub or 8 port hub.
Connect a LAN cable from the Netgear wireless router to one of the ports on the hub and then connect the other computers to the ports on the hub.
Sep 03, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
http://kb.netgear.com/app/products/family/a_id/1299
Aug 11, 2010 | NetGear RangeMax WPN824 Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Computers & Internet Logo
331 people viewed this question
David Payne
David Payne
