Question about Ovens
Neff B1541. 7 years old. Fan forced oven no longer working. If set to this function the oven simply does not heat up. Normal oven function setting working fine. What could be the problem?
    Genius:
  • 1,478 Answers
The problem could either be the power board on the oven or the fan element inside the oven has blown. This usually cannot be seen without taking the fan cover off inside the oven. Take the cover off to access the fan element and check the status, most likely it is blown and will need to be replaced.
Take care.
Posted on Jul 21, 2010
Hi got a NEFF B1691 oven. Thing is the oven light, element and fan keep switching off during cooking is this correct functionality - if not what could be wrong? The temperature display remains functioning...
There does seem to be a fault, as the fan should run continuously even when the element goes off at the required temperature setting, and the light should atay on as well.
It suggests to me that there is a fault with the oven thermostat, or it is wired incorrectly.
Dec 21, 2010 | Neff B1691 Single circotherm super...
Replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff B1421 Electric Single Oven
Electric main oven fan blows out only cold air
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 07, 2009 | Neff Ovens
Whirlpool 6MFOS oven not heating
Do you still have this oven? I broke my glass door and need a replacement. thanks
Oct 19, 2009 | Whirlpool Ovens
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
177 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
