Question about Compaq Presario Notebook
My mouse pad doesn't work - Compaq Presario Notebook
  • 6,826 Answers
Restore back to a time and date that it did work.
Otherwise, uninstall the driver in control panel, and let it reinstall if it is plug and play for windows 7, vista, or xp.
Posted on Jul 21, 2010
Ge wired mouse scroll wheel doesn't work
John:
The screws to open your mouse are hidden under the glide pads on the bottom of your mouse. remove the glide pads carefully and you'll see the screws. put the glide pads on with a non-permanent adhesive (like contact cement).
Jan 17, 2013 | Computers & Internet
MOUSE PAD NOT TURNED ON
Re-Boot doesn't help? Unplug, remove battery, plug in AC re-boot.If that does not work boot in safe mode. If that does not work let me know
Oct 29, 2012 | Samsung N Computers & Internet
Smart-pad Elan doesn't work
the sensitivity of the mouse may need to be set.
http://www.thetechrepo.com/main-articles/458-how-to-change-mouse-sensitivity-in-windows-7
Aug 30, 2012 | Samsung Computers & Internet
Jumping cursor on laptop
clean the mouse pad ,,, if doesn't work uninstall pad's driver and re-install the correct one... some laptops comes with joystick if yours have one clean it with a contact cleaner or disable it by unplugging it's cable ,,, if it didn't solve your problem replace the mouse pad or use a usb mouse ... :)
Mar 06, 2012 | Sony Computers & Internet
My touch pad is not working on my acer travelmate 4230
Hi, If the pad doesn't work you can get a USB Logitech mouse. It should work. Good luck..
Sep 23, 2011 | Computers & Internet
Hey my toshiba laptop pad mouse dosn't work it's frozen ,,i only bought it before 10 days ..and i can't use another mouse help me plz
This problem may occurs due to hardware fault or due to some setting changes doesn't matter that you did or not but sometimes it happened because of some other programs.
Here is the solution if it's not a hardware fault:
* Click on Start button
* Then select Control Panel
* Now select the Mouse option
* Under Mouse option window click on Device Settings and in that window touch-pad should be listed...
* Enable it.
Hope this will solve your problem.
Sep 10, 2011 | Acer Aspire 5610-4648 Notebook
The in build mouse of my laptop is no funtioning again. how do i go about it
You have to tell us the brand and model of your laptop. Anyway, in new laptops there is a button close to the mouse that can be used to enable/disable the mouse. Find it press it once.
If it doesn't work, go to control panel, locate mouse (under hardware), and change the settings to see whether it is working.
In laptops it is not actually a mouse, but a touch pad.
Sep 01, 2011 | Toshiba Computers & Internet
My touch pad wont work
please try to un-install and re-install the driver for the touch-pad. if that doesn't work then you have a bad touch-pad and it needs to be replaced. or you can use a usb optical mouse instead. refer to local service tech for parts
Aug 25, 2011 | HP Pavilion zv5000 Notebook
Touch pad does not operate. have uninstalled and reinstalled correct driver and PC device manager says device is working properly with no conflicting programs. generally, the pad did not really operate...
it is possible that the touch pad is disabled. Check control panel to actually confirm.
Since your touch pad is not operating, you will need an external mouse to perform this task.
Here is what you have to do to check if the touch pad is disabled.
Turn on your laptop, wait till it boots completely.
Click start,
Scroll to Control Panel select Control Panel.
Under control panel, (you will find a Mouse icon), click Mouse and a dialogue box will pop out.
On the dialogue box, click "Device settings".
Under device settings, you will find "Synaptics Touchpad..."
Highlight the "Synaptics Touchpad..." by clicking on it once, then click enable.
By now the mouse pad should be enabled. Apply the changes for it to take affect.
If the above doesn't solve the problem, try performing system. System restore can help to back date your computer to the time when the touch pad was working....
Go to Start > All programs > Accessories > System tools > System restore. Read and follow instructions.....
If the two solutions does not work, please let me so that I can further help you.
Yours sincerely.
Elect_Comp.
May 26, 2011 | HP G60-120US Laptop
Mouse frozen which keys to use instead my lap top works how I am able to write now. My Desk top computer mouse is frozen?
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse. If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows. If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
Apr 29, 2011 | Computers & Internet
Compaq Presario Notebook Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
