Question about Compaq Evo N610C Notebook
I recently disassembeled my laptop to fix the power adaptor inside it. After reassembely i cant boot my laptop. Disk read error. What can i do?
  • Compaq Master
  • 12,061 Answers
Perhaps you simply need to ensure you have the, correct HDD set and the boot device set properly in BIOS?
Make sure the HDD is working and OK, if you can use a HDD to USB "Dongle" and test the HDD on another PC, to see if it is indeed OK.
Posted on Jul 21, 2010
Tip
Solution for Most common blue screen error of windows.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
on Dec 01, 2009 | Computers & Internet
My studio gets a disk read error message every time it starts up and i cant fix it!!! it also says press ctrl+alt+del to restart but it does the same thing!
It seems that the boot sector has been damaged.
re-installing OS may help.
If you have important data on the disk, please install the disk as second disk to another computer and backup your data before installing the os.
Aug 16, 2010 | Dell Studio 17 Laptop
I have an acer aspire 3680 laptop and I get disk read error every time I power up the laptop and can't perform any other task. How can I fix this? My os is vista.
A Disk read error on boot means your hard disk has or is about to fail. to verify this you can try to fun a hard disk testing utility such as Seagate SeaTools, Western Digital Data Lifeguard, Hitachi DFT. These are all freeware.
Nov 10, 2009 | Acer Aspire 3680 Laptop
I can't charge my battery nor use the laptop.
SOUNDS LIKE U BENT THE COPPER WIRE INSIDE CHECK MAKE SURE THE WIRE INSIDE THE PC JACK IS STRAIGHT.SOLDIER COULD HAVE CAME LOOSE ALSO.
Oct 27, 2009 | Gateway MX6214 Notebook
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
Disk read error no recovery cd
the BIOS is hard wired into the motherboard and contains all information about the hardware on M/board.usually accessed by pressing del key or f2 key you will have how to do this at the bottom of the boot up screen read all info carefully it should list what your hard drive is and how big
also if hard drive is automatically detected
if you access it set it for default loadings and try again to boot
Jul 15, 2008 | Computers & Internet
Problem with the Booting/Hard Disk
If the IDE connection for the laptop is faulty, you'll need to obtain a replacement from the manufacterer (assuming it's user replaceable - unfortunately not all of them are). If you are comfortable going inside of the laptop itself, then you should be able to determine whether; 1. It's not simply come loose 2. It is indeed user replaceable and not fixed to the motherboard
May 26, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
Compaq Evo N610C Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
