Question about Bosch Freezers
Gefriert nicht mehr
Irgendwas klickt in meinem Bosch GIL 1240, als wenn der Gefrierschrank kühlen will. Der Gefrierschrank selbst gefriert kein Stück. Hat dieser Gefrierschrank einen Thermostaten den man überbrücken könnte, um zu schauen ob der Kompressor anläuft. Der Kompressor ist übrigens Handwarm, ich befürchte fast, der Motor ist hin. Er macht üble Geräusche, wenn man ihn etwas schüttelt.
Necesito reparar el mecanismo rotativo de los shelves o compartimentos. Que numero de la parte o motor debo instalar?
Antes de gastar en partes nuevas, debes desarmar el aparato y inspeccionar. Le llega la corriente al motor? Funcionan los switches de limite (que detienen al motor en su punto), algun engrane, o fusible quemado?
Dec 31, 2014 | True G4SM-23-RGS Reach In Specialty...
We have a Bosch upright freezer GSN32A20GB. Recently we got the AL code and whislt the fgreezer seems cold I am not sure it is working properly. The compressor is very warm to the touch but I...
See if you have a condenser fan near the compressor if you do it should run when the compressor runs. You may have a fan inside the freezer behind the rear wall if so it should run when the compressor runs also.
The frost on the coils could be a problem if it builds up and block the air flow between the fins.This would be a defrost problem.
Sep 12, 2011 | Bosch Freezers
Alarm red light on in my Bosch KGU32124 GB Fridge Freezer. What do I do?
more than likley its the thermostat stoped working,,its the part that tells the compresor to start up and cool things down, change the thermostat first
Jun 24, 2010 | Bosch Freezers
Drain plug freezes up and ice builds up in freezer then leaks into frig. How do you keep the drain free from building up?
Use a turkey baster filled with very hot water and flush it several times. That should resolve the problem. Also check the door gasket, if it is leaking, excessive frost would be visible causing more water then the system was designed to handle.
Good Luck,
Gil
Feb 28, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bosch fridge freezer stops working after approx 8 hours. Starts OK and freezes OK but next day it's warming up. Turn it off and back on again and it starts all over again and the problem reoccurs..
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Dec 10, 2009 | Bosch Freezers
Bosch freezer
Condensor coil needs cleaning.
Aug 02, 2008 | Freezers
Freezers Logo
122 people viewed this question
Top Bosch Freezers Experts
freddyfox
Harrie
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
