Question about Friedrich QuietMaster RS10J10 Air Conditioner
Energy Knight ac Model HMC24AD won't start up closes down louvres and blinks eight times
Where is the reset on my energy knight outside A/C unit?
If the unit wont start, there is a contactor relay in the unit that is not closing. You can check the contactor relay with a meter to see if it is being supplied with the voltage that it needs in order to close and switch on the compressor. If you are not getting any power to that, it could be the air handler in the house or the transformer that is not working right.
Sep 23, 2015 | Dryers
How to i get the timer on a Fujitsu Halycon inverter to repeat every day?
is not possibily,to any ac.the timer run just for 24 hours.on the power surce of your ac you can make a timer control programms, who take or give energy to your ac inverter(you put the ac inverter to run , and when the energy is shut down ,the ac inverter is stop working and when the energy is come back the inverter start working)
Nov 26, 2013 | Heating & Cooling
Energy knight wall ac unit wont turn on with remote? Model mss-012B
The only thing you can do that is not going to cost you a service call is to replace the remote and hop for the best.
Sep 08, 2013 | Heating & Cooling
My Canon image class MF5350d won't go into energy saver mode anymore
Odds are that some one did some panic button pushing at one time. You need to look in your owners manual or down load one from the web. Or you can go into the user settings and scroll down to were you see a setting for energy save. Good Luck
May 20, 2013 | Office Equipment & Supplies
Home AC Air Handler is making Annoying clicking sounds randomly
It sounds like the problem is with the louvre swing motor which is either opening or closing the louvre but not stopping at the end. This is due to a faulty intergrated circiut (IC) programmable chip on the PC board. Only way to get around it is to replace the board.
Jun 09, 2009 | Heating & Cooling
Energy Knight AC Blowing Fuses
My Energy Knight mini split air conditioner does not come on at all, no sound no lights nothing. I have changed the batteries with no luck. please help
May 28, 2009 | Comfort-Aire HMC24AD-1 Air Conditioner
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Friedrich QuietMaster RS10J10 Air Conditioner Logo
96 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
