Question about Garden
I have a watermaster model 57112 sprinkler timer. I have 4 stations set starting at 6:00 am each set for 60 minutes starting at 6 then 7 then 8 then 9 which means that all watering should be done by 11:00 am well it keeps on watering until 1 or 2Pm. How do I set it to run conseutive after each zone?
5 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: lost instruction manual to set
I can't locate any info on that timer. There is no timer that I can't figure out, I'm an irrigation contractor. Tell me what the face looks like or what buttons or dials are on it and I'll see if I can help.
Gary
Posted on Mar 12, 2011
  • 3247 Answers
SOURCE: I have 4 zones on
I cannot see the suggestions made by the other expert with whom you have been interacting. But I will try my best to guess.
Check the wiring on the new valves for zone 3 and 4 to make sure you have not shorted anything. Also please confirm if the new valves are of the correct rating for the controller. Are you using a common earth point for the valves? Make sure the earth and live are still clear.
Posted on Jun 27, 2011
aquaman987
  • 927 Answers
SOURCE: I just got an Orbit
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Posted on Aug 26, 2011
Testimonial: "Thanks Gary , you are a lifesaver, the instruction I got has no info about it, only unimportant stuff. U R amazing your instruction simple and great"
4 station timer help
Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Most major brands are linked here, including manuals for each.
Some brands such as yardworks, etc, repackage other brands and have no online support or clear resolution for warranty claim.
Open link, then add a comment with brand and model and voltage so expert can access same manual.
Replace battery. Reset timer. Check if unit is getting power. Check if outlet has correct polarity. Are some basic troubleshoot steps.
Most timers have 1 year limited warranty, and timer that came with used house may no longer be functioning. Or the sprinkler hear has gone bad.
For replacement, I think Intermatic mechanical sprinkler timers are better value than digital timers, since the mechanicals have repair motors and trippers and can last 25 years.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment for more information on timers.
May 22, 2013 | Hardware & Accessories
Trying to find a manual
1) Copy following link for sprinkler timer links:
2) Add comment March 2013 and describe timer in detail.
This will let me search files for same-similar timer, and find manuals that might be same-similar
3) Old timers, especially digital timers, are sometimes easier replaced with new.
Mar 07, 2013 | Hardware & Accessories
Sprinkler timerwont change stations
Re-post question with model number so expert can read manual alongside you. Otherwise it is guesswork trying to match your description to a timer.
Copy following link for assortment of sprinkler timer manuals
Aug 08, 2012 | Hardware & Accessories
I just got an Orbit 4 Station Sprinkler Timer with Easy Dial from the landscaper who did my sprinkler system a week ago, he set the timing at 6:30 AM I changed it to 5:45 and SET it and now its running...
Your FixYa Texpert,
Gary
Aug 26, 2011 | Garden
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have an Orbit WaterMaster Sprinkler control, it is hooked up, but there is a light bulb that says power off and the sprinklers won't turn on. They will turn on manually at the sprinkler station. Can...
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Apr 11, 2010 | Orbit Sprinkler System Power Source...
Garden Logo
246 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
