Question about GPS
Not aquiring satellite signals - GPS
  • 2 more comments
  • Anonymous Apr 25, 2008
    I bought a Nuvi 660 in February, and it constantly had problems acquiring satellites. Usually I could correct it by turning it off and on once or twice. Just this week that 'fix' stopped working. I downloaded new software, performed a master reset, but still nothing. Sending it back to Garmin for a new one.
  • glroark Feb 24, 2009
    After 1.5 years, Nuvi 360 has difficulty acquiring satellites. It would find them once in awhile only to lose again in 5-10 minutes. Resetting the unit did not help. Any other ideas?
  • dkadams57 Apr 09, 2009
    I have had my Garmin 660 about 1 1/2 to 2 years and now it suddenly cannot aquire sattelite signal and the screen stays on night setting. I have tried the reset button, downloading latest software, etc. Nothing has helped. Considering a new GPS device, but may not be Garmin.
  • bernied1945 Apr 23, 2009
    Have just bought street pilot i3 on amazon seems to still be showing location of previous owner .
Press and hold the start button Booting should appear on the screen, Then loading software will show on the screen when it has finished loading release the start button and the Gps will be like new
Posted on Jul 12, 2009
It seems to be a problem with Garmin's internal battery, you cannot replace it yourself. It has to be sent off to Garmin and here in the UK they charge £138 to replace the battery. They only last approximately 15 months then the problems begin, such as "not acquiring satellites". Won't be buying another.
Posted on Apr 26, 2008
Try looking up cost plus batteries if you have a location near you they can replace it cheap!!!!!!
Posted on Jul 08, 2008
My sportster 5 satellite radio is not getting signal
Is it "Aquiring Signal" or "Antenna Not Detected"? It could be the antenna, the dock, or the radio itself. For whatever reason, the Sportster 5 seems more fragile in the dock connections. TSS Radio has a repair guy who can fix this issue. You can reach him via email at sales@tss-radio.com
Jun 15, 2012 | Sirius Sportster 5 Satellite Radio...
The dispaley states "aquiring antenna" but never finds it,can this be fixed?
Yes. However, it depends on what is causing the acquiring signal message. It could be that you just have to replace the dock or antenna. But it could also mean the unit is going bad, in which case it would need to be repaired. www.tss-radio.com has a repair guy, though with that unit being discontinued for as long as it has, he may not have parts. You may have to search around for a replacement on amazon or ebay.
Jun 01, 2012 | Sirius Satellite Radio Sirius Sportster...
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
Aquiring Signal displays for 5-10 minutes before hearing audio
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
Jun 17, 2010 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Garmin nuvi 200w not getting any signal....
I recommend trying the hard reset and the newest webupdater (March 31, 2010) and se if you get better results.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 08, 2010 | Garmin nuvi 200W GPS
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
N ot able to aquire a satellite signal for two
have you downloaded the "HotFix" software update for the problem from Garmin yet? if not u will need a mini USB cable (avil on ebay for $5) and then register the GPS at this site www.mygarmin.com and select support or downloads and follow instructions..
Oct 01, 2009 | Garmin nuvi 255W GPS Receiver
I keep getting ''Acquiring Signal'', but a signal is never aquired
Try moving your Sirius radio antenna to a window that faces west. Signal goes through windows better than walls.
Aug 23, 2009 | Sirius Satellite Radio Audio Players &...
My tom tom ONe cannot get a valid Satelite Signal just stays wait
If you are indoors then move outdoors to get a signal.
If you are outdoors then move your location by a few yards and sometimes it will suddenly aquire the satellites.
Happens occasionally with my unit. I normally set a route up then start driving and it suddenly starts to work OK.
HTH
Peter
Mar 07, 2009 | Tomtom ONE GPS Receiver
Asquiring signal
yes everyone is getting "aquiring signal" problem, why isn't sirius radio taking responsibilty ???? it's thier satttelite ??????
glenn
Nov 10, 2007 | Sirius Satellite Radio Sirius Sportster...
GPS Logo
2,102 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
