Question about Dryers
How do i get tension in my new dyer belt - Dryers
  • 10,319 Answers
All dryers have a belt tensioner installed. If your belt came off before opening the dryer up, the tensioner is laying at the bottom more than likely. It has a pulley on it for the belt and the pulley should be replaced as well
Posted on Jul 21, 2010
The drum on my Maytag dyer model MDE308DAYW, will not turn with a heavy load why?
Because of one of the following
The belt has stretched (new belt)
The belt is slipping (new belt and clean drum)
The Spring on the idler pulley tensioner is weak. (Replace spring and lubricate pulley)
Dec 08, 2015 | Dryers
Whamaytag performa electric dryer model number pyet244ayw does not spinm?
Drum belt failure or worn drum belt has fallen off the motor pulley or tension idler has failed or reached its limit because the belt is too loose
Sep 03, 2012 | Dryers
Machine turns on but doesnt spin and dry clothes, what can be the problem
my dyer has a belt that broke it goes all the way around the drum and goes around the motor than to a tension spring if you take apart from back access panel unplug before attempting to fix look and see if the belt broke or came off tension pulley
Jan 27, 2010 | LG DLG5988 Gas Dryer
My dyer will turn on but the drum wont move
pop the top and see if drive belt is broken or fell off the tensioner sometimes tensioner will pop out of its slots due to an overloading of clothes
Jan 04, 2010 | Speed Queen AES28AWF Electric Dryer
HOW DO U PUT A BELT ON A KENMORE DYER
You,ve got to flip it over and loosen the tension pully. The old belt should come off, then replace the belt and tighten the belt with the pully by moving it over.
Nov 27, 2009 | Kenmore 63942 Dryer
Install dyer belt MAYTAG
Hello there
Here is a detailed instruction for you ok
  1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
  2. Replace the Belt
  3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt2.gif. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
    With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
  4. not too hard
  5. hope this is verry helpful for you
  6. Best regards MIke
Oct 15, 2009 | Maytag PYE4500AY Gas Dryer
When dyer runs it makes a squealling noise like abad bearing>
Could be felt pads and nylon glides on the front drum support are deteriorated.
Could be a sticky build up on the rear drum rollers.
Could be a worn belt tension roller.
Unplug the dryer.
Remove the front panel.
Remove the front drum support.
Remove the belt and drum
Inspect the items listed above.
Replace as needed.
Mar 11, 2009 | Maytag Dryers
Dryer
Your machine uses a belt tensioner of the type that the belt 'glides' on, creating a squeak noise that #1 will get worse and #2 is wearing out the belt. Replace the old tensioner with the one pictured here. The squeak will go away and the belt will last longer.
If you need further assistance, or instruction on disassembly, let me know
Regards,
reg501
Jun 27, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
