Washing machine won't drain
Hi I have an LG Fuzzy Logic Top loading washing machine, model WF 801 it goes through the cycle until the drain water part then it stops and the Drain error light flashes. could anyone tell me what the problem could be and if I can fix it without the need to buy a new part.
Many thanks Mary
  • rafat01 Jan 31, 2009
    as soon as the cycle reaches down the time 12 it should darin the water, i can hear the sound of the motor trying to pump out the water, no water comes out through the drain pipe, and the doesnt spin because the water is not darined completely.
    please advise the prabable reasons.
  • 975 Answers
I think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Posted on Apr 22, 2008
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
My LG Fuzzy Logic 5.5kg WF-T552TH machine works fine on small loads, but if I put a large amount of washing it, just runs through water and never starts the wash cycle. Water just passes through.
This is a very common issue and simple to fix, the height of your drain hose is too low, it is siphoning the water out of the machine once the water level gets up near the level of the drain hose.
Mar 02, 2012 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Lost manual to LG washing machine WF-T502c Fuzzy Logic. Just want to know where detergent and softener go?
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Jun 13, 2011 | Washing Machines
I have a Brand LG Top loader washing machine (Fuzzy Logic WF-T9235TP), it continue draining the water even if I am starting to wash
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Dec 20, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
338 people viewed this question
Top Washing Machines Experts
