Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Hi.. i just want to know how to fix upper keys of my keyoard where @ sign is and other it doesn't work as it use to be thank you.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 98 Answers
You need to keep the shift key pressed.
Posted on Jul 21, 2010
Car stereo
try pressing & holding the on/off or menu/settings button for around 10 -15 secs....
Feb 04, 2013 | Ford Vehicle Parts & Accessories
How do i unlock the pointer pad on my easynote
It sounds like your touchpad has been toggled to off. You need to toggle it on.
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
May 16, 2012 | Computers & Internet
HI, my maxtor basic 500 Gb doesn't start in Windows 7. After plug it , the SO doesn't see it. Can you help me?
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jun 21, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
How do i type a positive sign in loptop computer
There is a + key (same key as = key) on the keyboard. Try looking in the upper right area of the keyboard to the left of the backspace key. Press the shift button and the + button to type the + symbol.
Please let me know if it helps.
Thanks
May 01, 2010 | Acer Computers & Internet
My Dell E521 desktop dvd / dvdrw drives don't work
HI,
These instructions are for XP but it works in Vista too. The difference being how you get to the Command Promp and plus sign (+) vs. arrows.
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Restart your Computer in order for the registry - fix to work.
Please leave me comment, if you need further assistance
Rnj VinodKumar
Mar 10, 2010 | Dell Dimension E521 PC Desktop
When starting my Lenovo Think Pad laptop T400 there is an error message 0210 stuck key 50, what does this mean and what shall I do
Hi
Thank you for your query
Please try the following
1) Hook up a external keyoard to the USB/PS2 prot and see what happens
2) Press all the keys several times when the laptop is switched off to ensure that the keys are not stuck i.e. with debris etc etc
if this fails it would seem you have a bad keyboard, and would be looking at getting replaced
Please leave feedback/vote if my answer was helpful
Feb 12, 2010 | Lenovo ThinkPad T400 PC Notebook
My dish network remote isnt working with my LG tv
Not all TVs are supported by our remotes. You can do a power scan to see if you can find one that works or you can get the newest remote type that supports a large array of TVs. The new rmote is a model 21 which will work in IR and UHF mode. To perform a power scan do the following: Press and hold the upper left TV button on the remote until all lights on top light up and release.Now press the small red TV button and release - the upper tv button should be lit solid. Now press the arrow up key slowly until set turns off. Once it does presss the arrow down key once and then the arrow up key and the TV should power on. Now press the pound sign and the rrecord button. Now press the upper SAT button and release . You should be able to control the set now. Thanks for using Fix Ya.
Apr 07, 2009 | DISH Network IR Remote Control
Hi, I found a Wurlitzer organ that I am thinking of buying but the D, D#, F and F# keys don't work of the upper and lower key boards. The keys sound responsive but don't make the noise that an organ key...
You may have trouble finding the parts for that. But if you know a place where to get the parts for such brand and model then you just have to buy replacement for the rubber contacts of all the keys, it seems though sequencial keys maybe it got dirtied by some liquid and the owner did not try to clean and dry. maybe you can have it checked or try to keep a closer look in the keys, the area that keys doesnt work if any sign of liquid spill before. no use getting it if you find some sign of it.
Jun 19, 2008 | Audio Players & Recorders
My apple iphone(touch screen spoilt
I have the same problem my iphone dose not work frome uppers please inform me what can i do?
Thanks,
Ibrahim
May 06, 2008 | Apple iPhone Smartphone
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
