Question about Best Software ACT for Palm OS - Instantly Access Every Contact Detail (804526027776)
How to fix msn messenger. it says you cannot sign in because of internet. how do you fix it?i can go on internet.
  • 75 Answers
Click on start->run and type %temp% and delete all the files
and then try again
if this would not work,then you willh ave to reinstall msn messenger
Posted on Jul 21, 2010
Cannot sign into msn
MSN messenger is shutting down. You should download skype and sign in with your msn messanger account to have all your msn contacts.
Apr 04, 2013 | Microsoft MSN Messenger Connect Service
There is no way I can access my MSN Messenger. I tried just about everything. Can you help?
What about using web MSN messenger service from KarooLark http://karoolark.com/#msn
All you need to do is visiting, signing in and chatting.
Jun 24, 2011 | Microsoft MSN Messenger Connect Service
Error code: 80072efd
If you can't sign in to MSN Messenger, the connection settings in MSN Messenger might be preventing you from connecting to the Microsoft® .NET Passport or Microsoft® .NET Messenger Service. The MSN Messenger Connection Troubleshooter can often find and fix these problems. The Connection Troubleshooter starts automatically if MSN Messenger encounters a connection problem. If you choose not to use the Connection Troubleshooter, or it does not solve your connection problem, try the following:
1. Click the Tools menu, and then click Options.
2. In the left pane, click Connection.
3. Under Connection Settings, click Test Connection.
If you agree to allow the Connection Troubleshooter to examine your system, it will test for connection problems and report steps you can take to correct them.
4. Optional: Perform advanced troubleshooting
To troubleshoot your specific type of connection, click Advanced Settings. On the Advanced Connection Options dialog box, check that the settings for your particular connection type are correct. To test your connection, click the Test button. Click OK, and then click OK.
5. Click OK.
When you choose these settings, MSN Messenger will use the Microsoft® Internet Explorer connection settings if possible.
6. Try signing in to MSN Messenger again.
Hope I helped MSN expert Dr Reed
Oct 25, 2009 | Microsoft Windows Live Messanger
My msn messenger won't sign on. I've managed to remove it with zapmessenger then I downloaded it again. But I have the same problem.
hi this is kamal,
if ur msn messenger won't sign so pls uninstall msn and reinstall again
best regards
kamal singh
Oct 09, 2009 | Microsoft MSN Messenger Connect Service
Olve error code 80072ed quickly and easily
5. Click OK.
Sep 25, 2009 | Microsoft Windows Live Messanger
Cant sign in to wlm
5. Click OK.
Sep 16, 2009 | Microsoft Windows Live Messanger
Msn key ports will not fix!
Dear Friend,
First of all, always check the status of your web browser before signing in to windows hotmail messenger.That means that if you try to sing in, be sure that work offline mode in your browser is not checked.Secondly, have you run the MSN MESSENGER port configuration?Third and most important, have you opened the ports in your firewall?
Here is the list of thee ports that MSN Messenger uses:
1366 MSN Messenger
1367 MSN Messenger
1838 : TCP MSN Messenger (Gamevoice)
1863 : TCP/UDP MSN Messenger primary (incoming)
5190 : UDP MSN Messenger (incoming)
6891 : TCP MSN Messenger Filetransfer (incoming) - ports 6891 - 6900, one port per file transfer
6901 : TCP/UDP MSN Messenger Voice Telephony (incoming)
5004 : UDP MSN Messenger, ports 5004-65535. Used for AUDIO and VIDEO. Caution: securty risc! Do not open ALL these ports!
5004 : UDP MSN messenger (dynamically uses a port in this range 5004 – 65535 - requires uPNP in your NAT router and/or firewall). Used for AUDIO and VIDEO. See Microsoft website for details....
Good Luck!
Jun 22, 2009 | U.S. Robotics (USR8200USR8800KIT)
'We can't sign you into Windows Live Messenger'
haha it worked for me i fixed my problem. Try this it might work or might not. Go in to internet explorer and make sure work ofline is not ticked or make sure theres nothing wrong with your internet explorer. Try downloading the latest internet explorer. :D Hope this helps
Mar 30, 2009 | Microsoft MSN Messenger Connect Service
MSN Live is not Responding, I sign in to MSN Messenger Live and it doesn't respond. What can I do to fix this problem with MSN Messenger Live?
HEY guys!!
i had da same problem i went to google and i didnt find any way so i start finding it my way ..IF msn is not responding after 3 seconds when you signin...And if you did system restore dat what had happened to me ... i ve the answer... Go to Control panel> firewall>exception> .... IF YOU VE MORE DAN TWO WINDOWS LIVE MESSENGER CHECKED..here is da mistake ...just uncheck one and signin and see..IF its again not workin check the other one.. CAUTION: leave da msn (phone) NO NEED ........I HOPE MY ANSWER IS HELP FULL
Nov 10, 2008 | Microsoft Windows Live Messanger
Computers & Internet Logo
62 people viewed this question
Top Best Software Computers & Internet Experts
Michael Galve
Michael Galve
Lee Parker
Lee Parker
Martin Graham
Level 1 Expert
Are you a Best Software Computer and Internet Expert? Answer questions, earn points and help others
