/etc/master .passwd: Input/output error -sh: /etc/profile: Input/output error -sh-2.05b# CSRHIDTransitionDriver::stop I0BluetoothHCIController::start Idle Timer Stopped -sh-2.05b# My Macbook froze I tried to force quit and it would not. I turned it off and when I turned it on this is the message I received. I tried Start Up Disk but computer will not recognize disk. I here it running just nothing happens. I have tried the single user mode startup in as many ways as I have read to do but to no avail. I hope you can give me a clue as to what is going on and what I can do to rectify. I appreciate the help. Thanks, DPeters
  • redbus79 Apr 22, 2008
    I tried the test. Showed nothing wrong with hardware. Tried cd rom with ctrl+left shift and delete key. no difference. Same message that was in my first post. One more thing I noticed
    I tried the test. Showed nothing wrong with hardware. Tried cd rom with ctrl+left shift and delete key. no difference. Same message that was in my first post. One more thing I noticed is the light on the front right comes on when I turn the mac on but goes out at start up.
    Genius:
  • 1,447 Answers
Did you run the hardware test already by pressing the D key when starting up? Try force booting by turning off mac with the installer inside your cd rom then turn it on and press and hold down ctrl+left shift and delete key
Posted on Apr 22, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 22, 2008
    Try to hard reset it, then you'll have to reinstall disc. turn it off and hold down option key then turn it on, it will ask for the admin password
    Link for shortcuts
    http://docs.info.apple.com/article.html?...
  • 813 Answers
Hi frined
ur os has lost some files so u have to reinstall your os
Osx 10.0.3 lost password
Try this...
Hold Apple+S when booting to enter single user mode
  • #sh /etc/rc
  • #passwd yourusername
  • #reboot
If you can't recall your user name, you can either look in the /Users folder (the directories are named by user), or run "niutil -list . /users".
Also, on older systems the /etc/rc script isn't available, apparently. If that second step fails, try mounting and starting the base services manually:
  • #/sbin/fsck -y
  • #/sbin/mount -uw /
  • #/sbin/SystemStarter
I've had to do this a couple of times for friends when they've bought a second hand machine, and once when I had a momentary brain lapse and forgot my own password. Works like a charm, though you'll loose any passwords stored in your keychain.
Feb 17, 2014 | Apple iBook G3 Clamshell (M2453B) Mac...
I forgot my password,its an apple mac book model A 1811
Assuming you haven't locked out OpenFirmware, it's a pretty simple task to change your password back to something you know.
Here's how:
  • Hold Apple+S when booting to enter single user mode
  • #sh /etc/rc
  • #reboot
  • #/sbin/fsck -y
I've had to do this a couple of times for friends when they've bought a second hand machine, and once when I had a momentary brain lapse and forgot my own password. Works like a charm.
May 01, 2011 | Computers & Internet
Password problem
Here is a quick fix for resetting your Mac password.
1. Hold Apple+S when your Mac is booting to enter "single-user" mode.
2. Type "sh /etc/rc" without the quotes.
3. Type "passwd USERNAME" without the quotes, replace USERNAME with your actual Mac username you forgot the password to.
4. Reboot your Mac by typing "reboot" without the quotes.
Hope this helps.
Mar 29, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
How do connect the sh-8020 to a maantz reciver
sound source(cd or dvd)-----to equalizer input-------equalizer output------to marntz input(line in or tape in).
Oct 04, 2009 | Technics Audio Players & Recorders
"MS Outlook 2007 has stopped Working"
Make sure MS Office Outlook is not running.
Go to Control Panel.
Click on Mail.
Click on Show Profiles.
Click Add.
Give a name to the new profile.
Check the Always use this profile radio button and choose the newly created profile below it.
Start MS Office Outlook with the new profile.
Jun 08, 2009 | Microsoft Office Professional 2007 Full...
How i transfer data from window to linux
Depending on your linux distrobution, you will need to check the /etc/samba or /etc/smb configuration file, within that file there will be a place to set your windowsfile sharing password. then you will be able to transfer data across the local network between your linux / windows machine again..
however, if you've actually changed the password for the linux user account that enabled the samba file sharing, you will need to either remember that password, or set a new one from the root account byt typing the following command in a terminal / bash / shell session:
Task: Set or change user password Type passwd command as follows>
$ passwd <user>
Output: Changing password for <user>
Enter new password:
Retype new password:
passwd: password updated successfully
NOTE: when typing the password, you may not see the password you are typing..
You need to replace <user> with the username you are changing the password for.
May 25, 2009 | Dell Dimension 1100 PC Desktop
Black screen with codes. Help anyone?
Replace your Bluetooth device if external, and have the unit serviced if the Bluetooth device is internal.
Apr 30, 2009 | Apple MacBook Mac Notebook
Please advice me as soon as uyou can ..thx
Start troubleshooting the problem by checking the physical layer (Plugs, Jacks, Cables). Replace them with known working equipment.
Once you have traced the line from your Cisco to each other end (through to ISP, and to network switch), then reset your error counters, by restarting the cisco.
Check the ethernet interfaces on the network switch and the Cisco. Make sure they are both set to Autonegotiate or both set to the same settings like 100mbs Full-duplex. If they are not communicating the same way lots of errors will be generated.
Nov 09, 2008 | Computers & Internet
Mac G5 startup problem
Try an archive and install of the OS. This will save your settings and files but reinstall the OS. You can do this by booting to the cd and choosing archive and install instead of erase and install. If it happens again, it could be a slowly failing hard drive developing bad sectors, or the less likely of bad ram.
Apr 06, 2008 | Apple iMac G5 Desktop
Computers & Internet Logo
285 people viewed this question
David Payne
David Payne
