Question about Nintendo Super NES Console
Hi the problem with my snes is that its not turning on. its plugged in an still no power when i hit the switch. do you kno wut internally is wrong or you think its the power cord?
  • Nintendo Master
  • 429 Answers
Well I had a problem with my super NeS console not turning on so I tried a new ac adapter and it was fine after that it could be a bad adapter like I had I hope or the worst case is that the console has died then.
Posted on Jul 28, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: my SNES wont turn on. PLEASE HELP!!!!!!!!!
go buy a new one that system is to old
Posted on May 06, 2009
I was driving on the highway my car spun out of control, causing me to hit the back passenger rear tire up against a cement block on the highway. it looks like to me my tire is pushed up in the wheel hub...
There are a few things that can be bent or broken, I'll list them in order of most likley - the wheel is bent, strut assembly, lower locating arm, bearing hub. With-out knowing how to check them, you should have a Tech have a look.
Mar 07, 2011 | 1999 Chevrolet Lumina
I dont kno wut wrong whit dat back ligth and brakes ligth dont work can u help me
There it a switch that controls the brkae lights Its on the upper part of the pedal you have to look up under the dash board The pedal has a rod that attaches to it with a pin that has a clip on one side The switch is right there the pin runs through it Remove the clip slide out the pin and the switch comes out There is also an adjustment for the switch you may not need to replace the switch the adjustment may correct the problem If the switch is bad there easy to get at any parts store and about 10 dollars good luck
Nov 24, 2010 | 1991 Toyota Camry
My SNES won't turn on.
The system fuse is blown on your SNES. This is sometimes caused by pulling the game out or putting a game in without turning the power off.
If you don't have any soldering skills, it's best to let professionals replace the fuse. Search Google for part SNSPT010 if you can solder a new fuse in.
Sep 14, 2009 | Nintendo Super NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
BROKEN adapter PLUG IN ON SUPER NINTENDO
The dc jack where you plug in the ac adaptor is worn out which is why it is chipping and also why you can't make a good enough connection for the ac adaptor so you can turn on the Super Nintendo.
What needs to happen is your SNES needs to have the old dc jack taken off and a new one soldered on.
If you can find another broken SNES that has a good working dc jack then take if off of that one and solder it onto yours and your SNES will work like new.
May 28, 2009 | Nintendo Super NES Console
My SNES wont turn on. PLEASE HELP!!!!!!!!!
May 03, 2009 | Nintendo Super NES Console
Can't work SNES
Is the TV tuned to the same channel as the SNES ?
Both have to be set to channel 3 or both to channel 4.
Jan 18, 2009 | Nintendo Super NES Console
No power
it sounds like he triped the internal fuse on the tv when he surged the power
Dec 01, 2008 | Hitachi P42H401 42 in. Plasma HDTV
SNES doesn't display?
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC), as does every original SNES game cartridge. Before a game is loaded, the console will attempt to communicate with the CIC chip on the game cartridge. If the CIC chip doesn't respond or does not correspond with the consoles CIC, the console won't load the game. In most cases, a black screen is displayed."
http://www.chronicgames.net/articles/snes-museum.aspx
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
Jun 14, 2008 | Nintendo Super NES Console
Super Nintendo
I'll just tell you how to set it up with an RF cable.
1: Plug the power adapter in an outlet and plug the other side in the designated spot where it fits. Simple.
2: On the back of the SNES, there should be a switch that says channel 3 or 4. Whatever one the switch is at, it will be the channel to play it at.
3: From where it says "NES CONTROL DECK" on the RF switch, plug that into the SNES.
4: From where it says "TV" on the RF switch, screw it into the supplied ports on the TV. Note that newer TV's don't have this port.
You probably don't need to bother with the antenna port.
Enjoy the SNES! :)
Nov 10, 2007 | Nintendo Super NES Console
Nintendo Super NES Console Logo
180 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
