Steering Wheel
Removal & Installation
Special Service Tools (SST) Required:
To Remove:
To Install:
The fastener is prevailing torque type and may only be reused if the fastener and its counterpart are clean and free from rust and the fastener develops 27 inch lbs. (3 Nm) of torque or drag against its counterpart prior to the fastener seating. If the fastener does not meet these criteria it must be replaced.
SOURCE: R&R Steering Wheel Assembly and/or Steering Column Assembly
if you disconnect the battery and let it sit awhile this will disable the airbag.
SOURCE: steer wheel assembly
Hello Kimkaye.
There are three bolts that have come loose and will need to be tightened.
Some special tools will be needed to disassemble in order to access these bolts.
I would recommend a professional to do this job for you as there are many parts and pieces to contend with in this job along with the supplemental restraint system (airbag).
REMOVAL & INSTALLATION
The steering lock/ignition switch/warning buzzer switch assembly is attached to the steering column by special bolts whose heads shear off upon installation. The bolts must be drilled out to remove the assembly or be removed with an appropriate tool. The bolts may also be removed with a hammer and chisel by notching the bolts and tapping them counterclockwise with the hammer and chisel.
The ignition switch or warning switch can be replaced without removing the steering lock assembly. The ignition switch is on the back of the assembly and the warning switch is on the side.
CAUTION
The models covered by this guide may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Chassis Electrical .
