Question about Car Audio & Video
How would you read the the diagram and be able to tell which wires are on the top and which are on the bottom? of any installation mannuel on a stereo
    Brigadier General:
  • 3,917 Answers
Here is the complete set of instructions with videos which makes it easy to understand how to install the stereo refering to a installation manual.
http://www.ehow.com/topic_2986_wiring-car-stereo-system-101.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 23, 2010
  • 11,800 Answers
The wire diagram in any installation manual is designed like when the device is viewed face up and from the rear. To find which wires are on top just look at the rear panel and find the wires that are on the upper row of the connectors.
Posted on Jul 21, 2010
Need a wiring diagram for an ignition on a 1994 gmc jimmy 4x4 4.3 vortech mpfi Thanks in advance
Hope you can read it? If not, I'll try something else. The top wires in diagram are voltage to ignition switch. The bottom wires are voltage from ignition switch.
Feb 12, 2018 | GMC Cars & Trucks
My dishwasher ( quiet partner I)has a blinking clean light it blinks 7 times indicating an error. I tried reseting it but that didn't work.
next time send the brand name and model number,from what i've seen if that light flashes 7 times you either have a bad heater or a bad computer board,you can remove the top panel with the power off,then remove the bottom panel you'll see a tech sheet there that will tell you about the error codes,you'll also see a diagram you can read the heater from the wires,depending on your model if you look at the board i think there's a red and white wire and a blue and red wire,pull the wires off and with your meter you can check the heater or pull the dish washer out,remove the wires on the heater and read the heater out there,whatever is easier for you,also on some models you'll have to look at the diagram you read it out from one wire on the door switch and the other of of the board but like i say you have to look at diagram to see what wires,if the element reads good set on continuity then you have a bad computer board. good luck
Nov 14, 2017 | Dishwashers
Need wiring diagram on compesor
The compressor has three terminals, Common, Start and Run.... The terminals read left to right, top to bottom just like pages in a book. So if theres one on top, its Common then Start will be the first one in the next row. If theres two on top, it'll be Common on the left and Start on the right then Run on the bottom.
The run capacitor wires in between Start and Run and line voltage is applied to Common and Run.
Apr 11, 2015 | Goodman CKL36AR36 Air Conditioner
Diagram assemble for pushrod tubes on 1983 shovel head
corks top and bottom. small tube on top with o-ring down. large tube on bottom with spring and cap up. slide pushrod through tubes. Hold tubes up with a piece of wire and adjust pushrod. Remove wire and extend tubes from lifter block to head. Depress cap and install spacer between spring cap and top of top tube.
Sep 01, 2014 | Motorcycles
How do I wire a ignition control modular?
Your new module will be the same as the one your replacing
(should be)
The connectors can only go one place
You also can see the wiring diagram (no one even tries to get
one of them) That alone is a A+ to you
Aug 13, 2014 | Cars & Trucks
Escort gt wiring diagram
Two sources for this. I am told that Fixya is suppose to have this resource. Second is Autozone in their online Webpage at the bottom of the page.
You need to register for free on their site. They give you 12 free lookups. There are both Free and Pay sections at the bottom of the page.
If you look up your individual car, then the Wiring section or Electrical, eventually Diagrams will be displayed. The Diagrams have abbreviations for the wire Color. Y= yellow and so forth.
You can manipulate your Browser for a close-up or try using magnify after you have your first copy and work off of that.
Be careful that you actually have the right car. The vehicle is usually displayed on the wiring diagrams' lower right or left bottom corner.
I can not say much about our sites resources for Diagrams. Perhaps another Expert reading this can tell you more. Sometimes a Web search using the vehicle and "wiring diagrams" may help. There are many Pay sites, you will need to weed out them to get to the free stuff.
Sep 18, 2013 | Ford Cars & Trucks
Where can I get a wiring diagram for whirlpool speed top 2600 electric cooktop
Sometimes if you call the manufacturer of an appliance and have your model number ready, they will email you an diagram or mail it to you. I would not tell them what you are planning on doing, simply because of them not recommending doing this they may not give you what you need. Just tell them you need a diagram thats all. I've done this in the past and it was free, just depends on the company you are dealing with. Hope this helps, good luck.
Feb 11, 2012 | Cooktops
Pss26lg freezer is -20 in the bottom amd +20 in the top, the fridge side is freezing at the bottom amd 37 at the top, the fan is not running, if unplugged and allowed to sit for a few minutes the fan will...
replace the main board or the fan motor. after you replace one if the problem persists then you have to replace the other. then fan is DC on this model. if it is not telling the board it is running at full speed then the motor is bad. if the board is not putting out the proper voltage then the board is bad. it is a toss up unless you can read diagrams and test the proper wire at the main board. or call for service
Jan 07, 2012 | GE Refrigerators
Hi We are installing an alternator on a Hyundai Elantra 1998, and need a diagram to tell us where the belts go. Help! Rick
Most of the cars their diagrams top of the Fan 0r the bottom of the hood
It is going to show you how to install the belt step by step so check your bottom
Of your hood or the cover of the fan
Sep 26, 2010 | 1998 Hyundai Elantra
Kenwood kdc-119**
No, you have the battery wire hooked up to the ignition switch.
Here is the owners manual with wiring diagram.
http://inform3.kenwoodusa.com/manuals/KDC219.pdf
Yellow wire must go directly to fused HOT (battery).Not through ignition switch, red goes to switch.
Good Luck
Leadispenser
Jul 30, 2008 | Kenwood KDC-135 CD Player
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
