I hava a sansui 2gb mutlimedia player model san20084 and my daughter has somehow deleted the files the message is showing no files how cani fix it Thank you Robyn
  • kerro86 Apr 23, 2008
    I tried to load a song and the message was cannot create or replace, the directory or file cannot be created
    thank you
  • 13,433 Answers
Seems to me that all the songs are removed, try to add a few new songs into the mp3 player from your pc and see what happens.
Posted on Apr 22, 2008
How i fix msdc write sector error in memory card..........
sir i have a 2gb memory card but its not be deleted then i try to delete this , after loading show this message MSDC wright sector error, & then moved any file then show this message "access denied" please help me.
Dec 17, 2010 | Electronics - Others
Hello, the problem that I have with my SanDisk 2 GB MP3 player is that now, whenever I try to put songs on it, I get a message that "the device has stopped responding" or "the device does...
Try and reset the player first, If this does not fix the problem, Click this link to down load the Sandisk updater program to run a firmware update...Updater... Resetting the device: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Next time you need to delete files heres how. --
There are two ways to delete files on your Sansa player. You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device 1. In playback mode, press the Submenu button. 2. Select Delete.
METHOD 2 - Delete files using a PC For all other Sansa players: 1. Connect your device to the PC. 2. Select Open device to view files using Windows Explorer on initial connection. 3. Locate the folder where your files are stored. 4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. See this tip HERE
Capacity issue This error occurs when a Sansa player is almost filled to capacity. A Sansa player can NOT be filled to full capacity. (i.e. you can't put 2GB worth of songs into a 2GB player)
The player needs the extra capacity to create and maintain a "database", a database holds all the information such as playlists, recordings, song information, etc. The larger the amount of songs, the larger the database gets.
To resolve this capacity issue, you have to delete contents on your Sansa player using a PC.
STEP 1 - Delete files on your player 1. See first note on how to delete files on your Sansa player using a PC.
FAT corruption This error also occurs when there's a file system corruption in your Sansa player.
To resolve this issue, run error-checking to fix errors in your device using a PC
STEP 1 - Connect the Sansa player to the PC in MSC mode
STEP 2 - Run Error-checking to check and fix errors 1. Double-click on My Computer (Computer for Windows Vista). 2. Right-click on the drive letter associated with your Sansa player and select Properties. 3. Click the Tools tab and select Check Now. 4. Click both check boxes under Check disk options. 5. Click Start
If an error occurs while plugging in the player to the PC and some files are missing in the player, the database might be corrupted. To resolve this, you will need to format your player.
NOTE: Formatting will delete all files in the device. Your data (music, photos etc) is NOT recoverable.
Nov 16, 2010 | SanDisk Sansa e260 MP3 Player
MP4 player not playing music
Download the special firmware of your daughter's device , after that you shouldn't forget to restart it . The special firmware could be found on the manufacturer website .
Jan 20, 2010 | Audio Players & Recorders
My daughter has an Element MP3. She was using it
Scan it with an Anti Virus software. It may have a virus in it.
Jul 06, 2009 | Audio Players & Recorders
V@mp VP-408 not working
just conect to the pc then goto my computer then rigth click on mp3 icon then chose format itl wil delete al the files on you mp3 but its the only way to fix
plese rate like very helpful and vote me
thanks
Feb 02, 2009 | NHJ Limited VP408 MP3 Player
Thomson lyra 6675 Flash Mp3 Player 2GB
try flicking the "hold" switch then start up.
Apr 07, 2008 | Apple iPod nano 3rd Generation
Sansui video/dvd player recorder
What is model number of unit? Are you sure it records dvds?
Feb 22, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
DVD-RW will not finalize after recording
There is no solution for your problem. I thought my 4500 wouldn't finalize also but what is happening is that it didn't record on the disc you used. This is an older model unit and will not record on 16x discs. I believe you are boinked.
Feb 13, 2008 | Sansui VRDVD4005 DVD Player/VCR
Deleting songs
hi on my computer double click on the iriver icon and the folders data and media will show up. double click on the media folder and double click on the music folder all the files stored on the player will show up chose the ones you wanna delete and right click on it then press delete. This will take off all the files you dont want.
Dec 27, 2007 | iRiver T20 MP3 Player
Delete Songs No Music File
PLUG IN PLAYER GO TO MY COMPUTOR CLICK ON SANSA PLAYER,OPEN,GO TO FILES CLICK SHOW HIDDIN FOLDERS,THIS WILL BRING UP MUSIC FOLDER. DELEATE FROM THERE. ALSO YOU CAN REFORMAT AND CLEAR EVERTHING AND STSRT NEW.
Jan 10, 2007 | SanDisk Sansa e260 MP3 Player
166 people viewed this question
 Grubhead
Grubhead
