Question about E-Machines T1090 PC Desktop
Installing a 512mb PC133 memory module in a t1090 emachine. The pc wont recognize the module and wont boot nor go into post. Switching back to the original two 128mb modules and the pc works normal. Is there a limit for upgrading memory on this older pc or do I have a possibly bad module.
    Scholar:
  • 94 Answers
Hi there
Your t1090 will only accept a maximum chip size of 256Mb and so it will not accept the added the 512mb chip as it cannot handle it. 512 is the maximum size of RAM for this machine but unfortunately you cant put it in in one go
Posted on Jul 21, 2010
EMachine W3507, will not boot after adding 2GB of memory. (2x 1GB; one in each slot). It will boot with one stick, but only if the original 512MG is in slot 1. The 512MB is not recognized.
Where they purchased as a working pair some motherboards will only accept working pairs>?
Make sure RAM modules are of same brand and type try one ram module at a time in the working slot closest the cpu if both work individually they are not a working pair
Sep 06, 2013 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
Installed 512mb pc133 ram memory and it wont boot up
The laptop needs pc100 not 133 ram. it may be able to work on 133 but if you already have a pc100 stick in there it wont boot up. but all the recommended ram is only pc 100 and the Maximum it supports total is 512 mb
May 14, 2011 | IBM ThinkPad T22 2647 Notebook
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Hi everybody, I have a problem installing a dimm SDRAM Module on a MoBo Syntax SVX 400. User Manual says that till 4GB modules are supported. I bought a Transcend 1GB PC266 SDRAM module to increase the...
One long beep signals a memory failure - the stick you just bought is faulty. BTW there is no PC266 in SDRAM the maximum is PC133. PC266 is the first standard that appeared for DDRAM. so you most likely have bought something not right from the start.
Feb 07, 2011 | Syntax SVX400 (SYSVX400) Motherboard
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
Toshiba sp6000 512mb sdr 133mhz chips
These are the memory modules for your notebook, any others won't work. The max is 1024mb
You need these modules:
PC133 512MB (PA3108U-1M51)
PC133 256MB (PA3086U-1M25)
PC133 128MB (PA3085U-1M12)
If the modules you've installed meet the above criteria then make sure they are seated correctly.
Bear in mind it is always possible one of the modules is defective so try them one at a time, also they are non-eec.
Jul 08, 2010 | Toshiba Satellite Pro 6000 Notebook
T22 Doesn't boot on Memory upgrade
First make sure the memory is the same PC 100 , then make sure the chips are fully seated. and try rebooting computer. If you mismatch the Dimms the memory wont be recognized by the computer.
Sep 02, 2009 | IBM ThinkPad T22 2647 Notebook
Very slow boot
Bruce, the Dell OptiPlex GX260 normally will be equipped with a PC133 DDR1 128MB RAM module. It is recommended that you upgrade to higher memory bus DDR1 memory module, for example, 512MB/1GB DDR 1 running on 266 MHz to 533 MHz.
Hope this helps. Make sure u come back here if u still have further request.
Jan 08, 2009 | Dell OptiPlex GX260 PC Desktop
Memory upgrade for P6VEM3 MB
For this mainboard, you must use 168-pin, 3.3V unbuffered PC100 or PC133 SDRAM memory modules. You can install any size memory module from 32 MB to 512 MB, so the maximum memory size is 2 x 512 MB = 1 GB. As noted on pg. 9 of your manual. Shut down your system. Remove one dimm of memory & start the Pc. Does it boot & do you have video? No? Shut down & replace the the dimm with next stick of memory. Try again. Still no video? Replace memory with old memory. Did you regain video? In most cases of installing new memory it's found the memory just wasn't seated well enough. In few others the memory did not meet the correct voltage.
prazum post back your findings.
Feb 22, 2008 | EliteGroup P6VEM3 Motherboard
E-Machines T1090 PC Desktop Logo
164 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
