Question about HP OfficeJet 6110 All-In-One InkJet Printer
Carriage jam clear carriage jam , what mean?
  • Anonymous Apr 22, 2008
    I had a paper jam problem, I cleared the paper out of the copier, then the screen said to lift door and clear the carriage jam . I opened the door, but do not see any jam problem...How do you fix this?
  • Anonymous Jun 02, 2008
    My printer cartridge made a loud snap, and now it is stuck to the far left of the carriage. And when I say stuck, I mean stuck! I cannot see why I can't move it loose, but it is definitely being held or caught there on something. Any ideas?
  • 40 Answers
Turn machine on..
The unplug power cable on the back....
Press & Hold # 3 while connecting power cord.
keep it pressed & hold till screen display reset or shuts down...
Then follow the prompts on screen...
If this will not resolve the issue , then replace
call 1800 474 6836 & request them upgrade , You will save some money on purchasing new.
Posted on May 27, 2008
I tried to print something and the paper got jammed and now I have an error code 5100. What does this mean and how can I clear it? I have removed the jammed paper. please help me
the solution is to clean the strip film,look for the paper sensor is not broken or blocked
5100 means
- Carriage unit
- Timing **** film
- Logic board
- Carriage motor all this
Feb 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I get a message carriage jam and told to clear jam. However there is no paper jam. It tells me door open and it is not open. It seem the door does not go all the way up. I keep getting the message that...
It seems you mistook Carriage Jam as Paper Jam, but they are different issues. Carriage jam means the carriage that carries the cartridges is jammed which needs to be moved or be cleared manually after opening the door.
Please follow the instructions mentioned here (Click Here) [source HP Support].
Good Luck.
Let me know if you need further help.
Thanks for using FixYa.
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do I clear a carriage jam error on a Dell 942 all in one printer?I changed both ink cartridges and the carriage moved and let out a scratching sound and the error msg, clear carriage jam came up on the...
Carriage jam errors usually mean something is blocking the carriage from moving. It's usually a crumpled piece of paper left over from clearing a jam, or a faulty purge unit/capping assembly.
You should check to see if the printhead is locked or movable when you power off the unit. If it will move freely when it should be locked then something is blocking it from moving into the "home" position. If there is no foreign object inside then the capping mechanism in the wiper or purge unit may be broken or jammed. Oft times a good disassembly and bath for the purge unit will get it working again. However, this depends on how technically skilled you are and how much the machine is worth. It would take at least an hour in a shop. If you don't do it yourself and the machine is worth less than $100, it may be time to replace the machine.
Sep 24, 2010 | Dell 942 All-In-One InkJet Printer
Started with paper jam and then after that. Error message. Carriage Jam, print carriage access door. Clear and press ok. can't figure out what this means
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Jun 15, 2010 | Epson Stylus Photo 1200 InkJet Printer
What is a carriage jam
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper fromthe roller...return the paper output tray and the carriage access door. plugthe power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriageaccess door.
disconnect the power cord from the back..remove the paper output tray...lookinside if the carriage is stuck and if there is no papers or object that restrictthe carriage to move..return the output tray.. return the carriage accessdoor...
And lastly after doing this steps try to reset the printer and try to print..
To reset the the power button to turn on theprinter..disconnect the power cord from the product..disconnect the power cordfrom the wall outlet.. wait for 15 seconds.. plug the power cord to the wallsocket....plug the power cord at the back of the printer.. press the power onof the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 10, 2010 | Office Equipment & Supplies
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Apr 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
