Question about Motorola Mobility V980 Cellular Phone
Solution needed v980 no display here a v 980 not responce only gives pulse more then 5 by dgtal pwr supply no boot when key *# pwr in same time pressed.flex n duisplays seems vergin what to do better u say somthin dardware first provide pictures n another v360 network fluctuates in 1800 n 900 mhz
  • ashim rana Apr 22, 2008
    who dis person always a customer 4 mobile not in level of technician
Throw your mobile phone into the water. AKAL KE DUSMAN show it to a mekanik
Posted on Apr 22, 2008
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
Jan 10, 2017 | Computers & Internet
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
How do I get the pedometer to work on this unit?
Hold the pwr button for over 2 secs. to change modes. Tap to stop on first rt. arrow. (R resets to zero)--otherwise, tap to start and note blue arrow under "reset arrow). Start walking. Often it appears not to work but be patient. It will add all steps and/or jerks. When display goes blank, hit pwr. button momentarily for total "steps." It may be two steps off your count at times, but that matters not..
Sep 14, 2014 | CHOICEMMED OxyWatch CF309 Pulse Oximeter
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
Hoe to reboot pdt6840 scan gun
Warm Boot:
- Press the "PWR" button to turn the unit off.
- Press the "4" and "5" keys at the same time.
- While still pressing the "4" and "5" keys press and release the "PWR' button again.
- Release the "4" and "5" button.
- The PDT6846 should perform a warm reboot.
Cold Boot:
- Press the "B", "D" and "A" keys at the same time.
- While still pressing the "B", "D" and "A" keys press and release the "PWR' button again.
- Release the "B", "D" and "A" button.
- The PDT6846 should perform a cold boot.
May 03, 2012 | Symbol PDT6842-NIS632EU Portable Data...
6 hours old computer was working fine the shut down to load windows update then there was no video even unplugging and pressing the power button as aspire website suggested i have power but no video and...
Restart the computer and press "Del"key or F2 key.. check whether any responce on display, if BIOS is displayed , then display is ok.
Then restart the computer and press F8 key continuosly till "SAFE MODE" list displaying. if displayed safe mode list, select "Enable VGA mode". then press enter. try to login to windows. then change the resolution if required.
Jun 09, 2011 | Computers & Internet
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
Hp pavilion sleep mode
OK this is my solution we have discussed this a bit so I have come up with this -
1. Boot in safe mode if unable go into BIOS and restore factory defaults
2. Boot in safe mode by repeatedly tapping the F8 key (once every second or so)
Remember: Keep tapping it all the way up to the windows load screen
3. Once the prompt comes up hit Safe Mode
4. Once loaded in safe mode Go to Control Panel > Power Options
5. Switch everything to never - I always do this as it annoys me anyway
6. Reboot normally
If this doesnt work give me another messege I will be happy to work on this with you until we solve it
Jan 07, 2009 | Computers & Internet
Unlock Motorolan V980
What the person above said is so totally NOT true... i unlocked my phone by going online and searching for a way to unlock it... i can now do it anytime i forget my unlock code... It was a free and hassle free way of doing it... So there is a free way you DON'T have to pay some person or thing to get a unlock code...
Sep 29, 2008 | Motorola Mobility V980 Cellular Phone
Motorola Mobility V980 Cellular Phone Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
