Question about HEALTHRIDER H130t Treadmill Fitness Machine Exercise
All we can get on our treadmill is the blue flashing display lights and a funny noise. The belt doesn't work. We've tried resetting it several times with no luck. What do we do?
Same problem here any soulution at all ? ?
Posted on Jul 23, 2010
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
9500 hr belt stops when stands on it and funny noise from machine , noise stops when adjust front tension bolt but belt still loose
see the video and proceed. This happen because the lack of maintenance schedule . If the problem remain after you did LUBE is time to replace the old board belt. God bless you
Apr 01, 2013 | Life Fitness Used 9500 HR Treadmill
Image 17.5s walking belt doesn't work automatically
your information is NOT clear however, you must adjust the REED swtich, see the diagram, clean it, and tight the plug very well
2) RUN the software calibration, for diagnostic, troubleshooting, and fix it.
3) LUBE THE deck belt inmediately, maybe you have a worn deck belt, time to replace it.
God bless you
Oct 14, 2012 | Icon Image 17.5 S Treadmill
Error message "Speed Stall" stops will not run. :(
You must try a) LUBE very well the Deck belt and walking belt b) Recalibrate the machine.
If after this situation persist.
You must replace the EPROM(software is coming inside, and can be corrupt), call to the company.
for to get it.
Blessing.
How To Lubricate Treadmill
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 06, 2017 | Tunturi Exercise & Fitness
I have a proform xp 580 and my treadmill makes a clicking noise as if it is trying to incline what should i do?
1)Please lube the gear and shaft, very well from elevation motor
2) Test the motor, and replace if necessary.,see for ball bearing and lube
3) Lube the deck belt, and guide for instruction manuals.
4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it.
God bless you
Jun 08, 2012 | Proform XP 580 Trainer Treadmill
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
Treadmill belt stopped
Double check all your connection. Check to see if you may have pinched any wires. Also check to see if you have accidently unplugged or pulled a wire loose. If that's not the case it sounds like a lower board issue.
Jul 25, 2009 | Exercise & Fitness
I hear noise in my new treadmill
where did you buy the unit. you still be under warranty. noises are funny sometimes, you think it is hear but then its over hear. There will be noise fron under the belt that is normal. sometime it is louder in a house then in a store. you may need some waxon the deck as well. culd be plastic rubbing in the belt.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Apr 11, 2009 | FreeMotion Treadmill t7.3
HEALTHRIDER H130t Treadmill Fitness Machine Exercise Logo
98 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
greg kinsley
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
