Question about Sony RDR-VX525 DVD Recorder/VCR
I want to put my kids soccer games from vhs tape to dvd. I just want to put in the dvd and not have to select a title for it to play
  • 1,056 Answers
First you need a DVD recorder. You can also use a computer with a DVD burner but you would need one a device that is available on most electronic stores. It plugs into the usb and has input for audio and video. They cost anywhere from 75 to a hundred bucks. With a DVD recorder all you need is some audio video cables and start recording.
Posted on Jul 21, 2010
I have a grundig gr1000(b) vhs/DVD combo. Is it possible to record from video cassette onto DVD? It doesn't seem to be mentioned in the instruction manual. Thanks for your help.
Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
Nov 02, 2014 | Televison & Video
Vhs view block
It sounds to me like you have a blank tape or an SVHS tape, which won't play on a VHS machine though they look the same tape.
Jan 25, 2013 | Televison & Video
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
RCA DRC 8310 - not copying from VHS to DVD. When I am playing the VHS tape I press the COPY button, it says that is copying for about 10 seconds and then stops and locks up,. If I press the RECORD...
stay with the 8x dvd (these recorders look and only work with certain types of dvds)...if your manual says maxell stay with it dont look for the brandless sale...use 8x unless your have updated your machine with new firmware from the mfr. for that 16x...are you trying to record HBO / DISNEY? its not going to be allowed on DVD...yes you can record both onto tape...but not digital..(I put all my movies onto dvd, my kids still have tape DISNEY)
hope this help
Mar 10, 2010 | RCA DRC8300N DVD Recorder/VCR
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Feb 11, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I can play DVD's but not VHS tapes. I hav checked all connections and several tapes to no avail. Thank you ! Ol' Fred
Hey Ol' Fred...
One of my good friends is an ol Fred so I felt compelled to stop in and help!
I'm not sure of your setup, but if you've got a combo DVD/VHS unit, make sure that you have out puts to the TV for Both parts separately... You can designate by accessing the TV's onscreen menu and setting up a separate source for DVD and one for VHS. I've found on my projection TV that it's best to use the Coax cable connections for the VHS to TV.
Then once it's setup with separate hookups to the Tv, you should have audio and video for VHS...
k
Dec 18, 2009 | Televison & Video
Dvd-vr357
I do this all the time. Press Menu on your remote control. From there go to Copy then select VCR-->DVD. If you're recording from the beginning of a tape just press the Enter button. If you're recording from another place on the tape hit Play or FF to advance you to the spot you want to start recording. Stop the tape where you want to record from and hit Enter. FF to the place on the tape where you want your recording to stop. Stop the tape where you want the recording to end and hit Enter. Hit the Down Arrow on the remote control to highlight Copy All and hit Enter. Your machine will rewind to the start point and begin recording and it will stop when you get to the indicated end point. Note: If you have more than one episode/show on a VHS tape and you want separate titles for each, you have to go through this process for each title. If you have more than one start and end point for each copy command you'll just get different chapters not different titles. I hope that made sense!!! Hope this helps you out.
pjrsop
Apr 24, 2008 | Samsung DVD-VR357
Finalizing dvd
VHS tape to a DVD-R
Jan 13, 2008 | Zenith XBR413 DVD Recorder
Record vcr to dvd-r
This suggests that you are net setting up the DVD recorder up correctly,
Check- are you connecting to the correct 'INPUT; port?
Check have you select the correct chanell that points to this port.
Carefully go the the book- vey can be very dense to read.
Nov 21, 2007 | Zenith XBR413 DVD Recorder
Sony RDR-VX525 DVD Recorder/VCR Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
