Question about Microsoft Windows Server Standard 2003 for PC
Heardesk hw is not booting what is the problem
    Scholar:
  • 160 Answers
Hello
For solving your problem do the following:
1. Start the system
2. Press the F8 function key
3. Select the Safe mode option
4. Press enter
After booting you will get the desktop
wait for few moments and restart the system
If it wont works it may be due to failure of the OS and need to install the OS
Let me Know that you problem is solved and rate me as Fixya!
Posted on Apr 29, 2008
My computer gets halted after 30 minutes. I dont know what is wrong?
There can be a couple of issues there:
- HW issue:
Memory might have a defect
Graphics card has a defect
- SW issue (most frequent):
You have a virus. Get a bootable CD software like: http://www.hirensbootcd.org/download/ and boot your computer with this. Scan and remove the antivirus
Windows issue: boot the PC with the windows installation disk and go to REPAIR function.
In order to check if the issue is HW or SW, boot the PC and got o safe mode. If the PC halts also then, most likely you have a HW issue.
Jul 28, 2011 | Intel Motherboard
I have compaq presario v3000 and everytime i boot up, the pc detects new hw installed and that i need to install bluetooth LAN server access driver. How do i get the hw compatible with what i need to...
check your device manager if there s any yellow question mar or exclamation point and check the desription of that device. If no question mark it means that you dont have any device driver needed to be installed, there might be a specific bluetooth device that is added on your Bluetoooth Devices that is not on. Go to bluetooth devices then remove it ffrom the list,
Jul 17, 2010 | Compaq Presario Notebook
Hw to make a dual boot system...
Firstly put a an Operating System disk in the computer :
Boot from the CD as you need to format the entire Hard disk
Then Need to create two different partition to Load the OS .
Then Put the OS disk one by one and Install the Both the OS one by one on the respective Partition ...
Everytime need to boot from the DISK.
Mar 11, 2010 | Computers & Internet
Every time I open my pc,black screen displays. Then after the OS displays after that nothing. & after a minute it repeatedly displays the same. What' the problem with my pc?
The PC boot detection can be troubleshooted in stages.
I am just getting the process explained here. If your boot issue falls in any of the below said stages, Please do the needful as per the suggestion.
Stage: 1 When the Signal chip on the motherboard initialize the post operation and it checks for the Motherboard powersupply, baised on the Bios manufacturer you get a signal once the POST (Power on Self Test) finishes.
Suggession: If there is any problem at this point, the system hangs\or stops working as Bios wouldnt start its routines. You may have to contact a HW Engineer to find the solution.
Once the POST is done successfully, the Bios is initialised with the Routines to run a check on the motherboard, ports, devices attached and it inspects all chipsets and hardware details of the system.
This point you will see the tiny LE-diode flashing on keyboard and other attached devices. Cmos is loaded with the detailed HW information. As a heirarchy of inspecting the Hardware, it checks for the Audio first and then the Video chipset and status.
Any beep heard multiple or single long at this point could also be due to the failure of Display chipset or port or device. As the system cannot indicate the failure it uses audio. Here your VGA once detected it starts giving you either a non-graphic or graphic display of whats happening inside the system. (Boot process). Suggessions: Any issues at this stage needs to be fixed either on HW or Peripherals attache or finally on Bios if corrupt.
Once Bios routine is done the control transfers to a small program on Bios called bootstraploader which helps in finding the boot up files on the Active partition and initializing them. Here if it fails to find the boot files it shows the message usually known as "Non bootable disk"
Suggession: you can finalize understanding that the disk has no boot files or they are corrupt or the disk partition that has the boot files is not readable.
Suggession : 4: Once the windows starts loading and still it gets stuck at any point till you log on its all the OS files which plays its roles to get the system up. If there is a failure at this point, your OS is corrupt or has an issue. Suggession : Please do an OS Repair or at worst case and OS reinstallation. Hope this gives answers to your issue. Good Luck.
Feb 16, 2010 | Microsoft Computers & Internet
Hw to log in as administraror?
If you want to log in as administrator, keep hitting F8 when the computer starts. You'll find Advanced Boot Options. Select Safe Mode from there. When it goes into windows, you'll find administrator in the user list.
Jun 25, 2009 | HP Compaq dx2300 Microtower - RT950UTABA...
No display during boot
Try a different monitor. Could be burnt out.
May 10, 2009 | Intel DG31PR Motherboard
Nr138 intel 845 chipset = I need the HW manual please
Hi, If you have the HP D220 Desktop, you can download thier manual from HERE and the best motherboard diagram you can find (not that great) from HERE
if you have the NR 128GV (NR128 Scenic addition) you can get the manual from HERE
Hope this helps!
Aug 31, 2008 | Intel Motherboard
Boot failure
Try booting from a dos boot disk or windows startup disk, this will prove that HW is OK
then if it boots OK you may have a HDD problem.
Post back results
Jul 12, 2008 | ASUS P5S800-VM Motherboard
Desktop pc gets hang while booting in the middle
CHECK THE BIOS STTING AND START WINDOW IN SAFE MODE IF U GET SAME PROBLEM IT MEANS HW FAIL.
Jun 11, 2008 | Computers & Internet
Tascam 2488
Repartition and format the hard drive. There are specific instructions elsewhere on the Internet. I did this about six months ago. I believe my problem came about after I stored my 2488 on top of my monitors - I believe the exposure to the magnetic fields corrupted the boot partition on the drive.
Apr 10, 2008 | Tascam 2488 Portastudio Multitrack...
Microsoft Windows Server Standard 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
