Question about Frigidaire Refrigerators
My ice maker has stop working .mod FRT21TNGD3/FRIGIDAIRE
    Problem Solver:
  • 4 Answers
First need to determine water supply. Water filter and or inlet screen fouled? I know this is assuming the water supply is open..
Check the ice level bar to be sure it is in the correct position for making ice. If it is incorrect poition, the ice maker "thinks" the ice bin is full. I would start there with the water supply though. Most likely...
Posted on Jul 21, 2010
Ice maker is not pumping in water to make ice
check that its on and full level arm cutoff is not sticking then look at water inlet valve --and filter --
Jul 24, 2016 | Frigidaire Refrigerators
I changed the triple solenoid valve on my Frigidaire mod. FRS6LF7FS3 because frig not making ice. Still no ice. If I manually put water in the ice maker it freezes and dumps
Bummer deal. I would say trash is blocking the flow of water at some connection - maybe as it enters the cube-making device.
Feb 27, 2015 | Frigidaire Refrigerators
Frigidaire side by side Freezer only freezing top shelves, warm at the bottom
Its defrost issue.
Defrost cycle is not taking place on time or its not working at all.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Frigidaire Refrigerators
The ice maker has stopped making ice. Can still receive water but no ice.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 01, 2010 | Frigidaire Refrigerators
Frigidaire Side by Side Ice Maker Not Working
heatman101
980
May 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
My ice maker stopped working on my side by side mod. # plhs237za , water dispenser works , filter is new , any help?
You can try one that that I was successful with.
Unplug the entire unit for about a minute and the plug it back in and see if that helps.
Thanks
asnowman
Sep 04, 2009 | Frigidaire Refrigerators
My frig will not make ice. the mod # is
There are a few things to check.
1. Make sure there are no kinks in the tubing that supplies the water to the ice maker.
2. Change your filters. It way be there is too much gunk in them for water to pass through.
3. Make sure your water supply(from the wall or floor) is hooked up and works.
4. May be internal problem in the ice maker itself and you'll have to take it out and either bring it to a repair place then install a new one, or call a technician out to repair it for you.
Hope this helps.
Jul 07, 2009 | Frigidaire Refrigerators
Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Jan 05, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker only works for short time
I HAVE THE SAME PROBLEM WITH THE ICE MAKER FRIGIDAIRE FRS22WNC. IF ANYONE HAS AN IDEA HOW TO SOLVE IT PLEASE EMAIL ME TO HYATZFT91@AOL.COM
HIGHLY APPRECIATE IT.
NICK
Sep 07, 2007 | Frigidaire FRS23H7C Side by Side...
Refrigerators Logo
82 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
