Question about Frigidaire ATF6000ES Front Load Washer
It seems to run but it not running a full cycle and does not let water poor into the machine
  • 1,998 Answers
Have u checked the water valve in the rear u can do this by seeing if you have power to the water valve using a multi meter also i have seen on a few models such that they have these small screens inside of the water valve that are removeable and if there is any sediment inside of these the water will never hit the drum it goes into the machine and out the drain immediatly never hitting the tub so check both of these thing hope this helps
Posted on Jul 21, 2010
Where is instructiona for cleaning
Just poor in Clean Water into Water holder , NO COFFEE the let it run the full cycle. . You need to buy DESCALER from any Houseware shop
Mar 17, 2015 | Bella Dots Coffee Maker Red
How do I clean each of the water dispenser on model 3010 hamilton beach
You can use white vinigar or baking soda. I use baking soda because vinigar will dry out the seals over time. If you use baking soda, mix a teaspoon full in a small amount of water to break it up, fill the unit half full of water, add the mix, fill the unit with water and run the unit as normal. If you use vinigar, add one teaspoon to a full load of water and run the unit as normal. When the cycle is finished, fill the unit with plain water and run again to flush.
Hope this helps.
Oct 22, 2014 | Coffee Makers & Espresso Machines
Kenmore 300 model 110.28322700 won't run. motor makes humming sound
Pre Thanks for help.
I have read all above and these are my symptoms.
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
however i tested my lid switch with a multimeter and the lid switch seems to be fine.
What else could be my issue?
Kenmore 300 110.28322700
Dec 03, 2011 | Washing Machines
It seems to be flooding at the fill part of the cycle.. water level seems right but there is water coming out near the base at the back... The issue was first noticed after a finished cycle still was full...
It usually is, but you'll need to first determine where it's leaking from. You'll need to run it with the back off to find the leak. An exploded view should be available at www.appliancepartspros.com
Feb 14, 2011 | Hoover HTC243 Top Load Washer
Not all water comes through filter
2 cups white vinegar in reservoir, run full cycle, let cool, discard vinegar. Fill reservoir with cold water, run full cycle, discard water, let cool. Repeat clear water cycle.
Jan 22, 2010 | Bunn NHB Coffee Maker
Our screen says to "De-scale". Can you tell me how to do that? THANKS!
run one full cycle with 2 cups white vinegar. Discard vinegar and let machine cool. Run another full cycle with cold water. Let cool, discard water. Run second cycle with cold water. If this doesn't do it, repeat the whole process again.
Jan 19, 2010 | Coffee Makers & Espresso Machines
Shu3035 when i turn dishwasher on it seems to be
Hi I am Vortash it sounds like your vacum sensor has gone .. this is the device that tells the machine how much water it has in it , should this fail it sometimes confuses the machine into thinking it is full of water and is actually a very common fault with dishwashers and washing machines . So it carries on and does a full cycle thinking it is washing but has no water . If it was just the water feed solenoid the vacum would not allow the machine to run , but if the vacum is faulty it stops the feed from opening and allowing water in .
Another possibility is that your program panel has gone and requires replacement .. but I would try the vacum first as this would be the far cheaper option first ... Regards Vortash
Jun 25, 2009 | Dishwashers
GE washing machine does not run, gives humming noise
A washing machine is a simple product.
When trouble shooting anything you have to know what is supposed to do and what is it not doing.
At the begining of a washing machine cycle the machine fills with water until a switch is made telling the machine it is full and ready to agitate. Since it never fills it will stick in that part of the cycle.
When you start a cycle and no water enters the drum you have one of three problems:
1. The water supply is shut off.
2. The solenoid valve that supplies the water is not opening.
3. No power to the washing machine.
Since you are hearing a hum, the machine seems to be trying to activate that valve,
The humming noise comes from the electromagnetic field that activates the valve,
Dec 04, 2008 | Washing Machines
Maytag Neptune MAH5500B
only 2 or 3 real problems with this machine, bad machine controller( behind console) although lights on are sign that its good,
Either the pump is clogged and not draining water so it will never spin let alone spin full speed with water in tub, i also doubt that because it seems that s there just water within the clothes and not a tank full of water,
which leaves the last Major issue with machine and that's the motor controller, not telling the motor to spin.. could also be a bad motor but i really doubt that all....
This is a funny machine because depending on when it was made (serail number denotes its age) im looking up the model and your manual states that you have a 3rd yr to 10 yr part warr on the motor, Well on earlier models you cant replace the motor itself it comes as part of a kit, "NEPTUNE REPAIR KIT" which also includes the motor control board. reason i mention that is I"m able to get a motor controller covered by warr(as an authorized maytag technician) if the model will take the neptune repair kit, sure youll need to pay service and labor but the a part would be covered.
Mar 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
107 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
