Where is the oil drain plug on the 88 c.i. H D 2003 flstc
On all Softail models, look along the bottom of the oil tank from the right side of the bike. You'll see a line or hose going downward towards the transmission. Usually, unless the changed something, the line will come out along the frame down below and behind the transmission. There will be a plug in the end of the line. Remove the plug to drain the oil.
Good luck
Steve
Testimonial: "great help.I thank you and will use your service again.and refer you to others"
