Question about Garden
I have A 5hp lazy boy garden tiller. The chain assembly is locked up and A hole has worn in theright side of the housing beyond repair. Can you tell me where I can get A transmission chain assembly to replace this one. It is approximately 12-15 yrs. Old. It is otherwise in excellent condition. Please help. Thanks.
    Top Expert:
  • Garden Master
  • 52,162 Answers
The chain will be standard pitch and width so any bearing supply shop will have a chain to do the job
take the old chain as a sample for the measurements
Posted on Dec 17, 2017
5 Suggested Answers
SOURCE: both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Posted on Apr 27, 2009
  • 115 Answers
SOURCE: trying to put on pull cord on tiller.
you remove the cover, bend three tabs and the wheel will come out. Replace the cord in the manner that it is removed, rewind spring and install wheel, then bend the tabs back down.
Posted on Jul 04, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
SOURCE: I have a lazy boy tiller with chaine drive, its
The gear box can be removed, reset and resealed using gasket magic. It is not a quick fix and during this process I also replaced the tine shaft seals as I had lubricant leaking from the gear-box to the tine shaft. When you are tilling you should avoid rocky areas. It iseems sudden tension due to bouncing is what knocks the chain loose.
DO NOT remove the belt pulley from the top of the gear box. It is unecessary. You must remove the entire assembly from the rear of the machine. It is set in place by 6 bolts and come off as a whole unit. Once it is removed then undo the three bolts and spacers that hold the case in place. Remove the case from the frame by sliding it out the open end. You will have to remove all of the bolts around the outside of the case; a cordless drill really comes in handy here. Lay the case on its side, as you remove the bolts you may experience lubricant dripping from the centers of the removed bolt holes, or at the center holes where the case connected to the frame. This is not a problem as you will need to replace the 90 weight lubricant after you have resealed the case anyway. Once you have removed all of the bolts, using a flathead screwdriver and a mallet or hammer. break the seal around the outside of the case. You may have to go around a few times, but eventually it will pull apart revealing the sprockets, bound chain and remaining lubricant. Since it is open this is an ideal time to check for wear on sprockets and remove any large debris from the case. reset the chain so that the tine shaft moves freely and the corresponding sprockets spin as you move the tine shaft. Using a gasket sealant (Gasket Magic**) put a thick bead of sealant in the center of flat outside edge where the two sides of the case come together. Add a little extra around bolt holes. Replace the two covers snugly together and begin finger-tightening the bolts back into the crank case. Once you have completed this task, go back over the bolts and tighten with a hand wrench. Once the case is back together allow 45m to an hour for the sealant to completly harden before introducing lubricant to the system. Then reattach the case to the rear assembly and then put your tiller back together.
This occurrence seams to be an issue with these machines, however the problem is avoidable as it is persistant use in rocky or hard ground areas which causes causes the system to jump and bind. If you happen upon a hard patch of earth or rocky area, go slow, do not force the tiller and remove any large debris when possible before tilling.
Posted on May 08, 2010
Mantis tiller repair drive unit
you will have to tear down the unit and check it for stripped out gears, chains and sprockets.you may have to change out the unit as a whole assembly.i don't recomend putting a new chain on a worn sprocket as it will wear out the chain quickly. hope this helps.
Sep 02, 2014 | Garden
What size belt for lazy boy tiller
www.hyperparts.com/ope/LazyBoy-oem-list.htm
Jul 05, 2014 | Garden
How do I put a new pull rope on my 5hp MTD Chipper?
pull the starter cover pull rope out to length lock the housing the rope is in, in place with a tool pull out rope. reinsert new rope into retaining hoe tie a not and cut off excess rope. put ropr through handle hole reattach handle and remove tool you used to hold the rope housing. This is if your spring and starter assembly are ok. Or you could stop being a cheap and let a shop do it for 5 minutes labor.
Jun 29, 2014 | Husqvarna Chain Saw 20" Bar
I have a lazy boy front tine garden tiller. i want to have the proper amount of 90 wt gear oil in the transmission. I can see one hole with a plug that says gear oil. Do i fill the gear box up to that...
ITs not really a lazy boy brand is it? If we a re talking about garden tillers... then if the fill hole is on top the oil level should be about 1 ( one) inch below the hole. If the hole is on the side of the gear case then it is a peep hole and should be filled till fluid runs out.
Oct 24, 2012 | Garden
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
I have a lazy boy tiller with chaine drive, its liked locked up. it will not engage, any help please ! it does have aplace to put oil on the side of the chine drive house. what kind of oil would it take?...
Jun 16, 2009 | Garden
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
