Question about HP ScanJet 5370C Flatbed Scanner
The light on the scanner is flashing intermittently hence it will not operate
    Scholar:
  • 163 Answers
When the light bar flashes or blinks, the built-in diagnostics are reporting the hardware is not functioning as expected; it does not necessarily mean the scanner is defective. Before contacting HP for service, perform the following:
  1. Turn off the computer.
  2. Disconnect the power cord and USB or parallel cable from the back of the scanner.
  3. Unlock the transport lock several times to ensure it is not restricting the movement of the carriage. Make sure it is fully open before proceeding to Step 4.
  4. Wait 60 seconds before connecting USB or parallel cable and the power cord to the scanner.
  5. Turn on the computer and rescan to test.
If the light bar flashing is accompanied by a 2117 error, also try the troubleshooting steps included in document: Bps03134 - Scanner not Responding 2093, Unidentified Program Error.
taken from hp support website
Posted on Jul 21, 2010
Testimonial: "Quick response. Fixed the problem. Thank you"
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
Chuggs and has hard time shifting
You need to have a real good scanner connected to this. The onboard computer diagnosis will sometimes store intermittent Codes but needs to lock a Code for cheaper scanners to read.
You will save money by using the right equipment and buying only the parts you need.
At 55MPH you are way past Torque Converter lock-up speeds. Could be speed sensor not giving accurate info to PCM.
Feb 14, 2014 | 2006 Lincoln Navigator
Check engine light comes on and only stays on for a few seconds, havent noticed anything different when it happens... ???
You can get free scans at Autozone, Advance, or Oreilys. Sometimes a better scanner is needed at a Dealer because the cheaper scanners need a "check engine" light to be on steady to get a reading.
The better Dealer scanners can access "Intermittent defects" logged in your onboard computer. It all depends on the design of the onboard computer as some will accumulate the Intermittent defects and may set a steady "Check" code after a number of defects are registered. Other designs may just ignore or lose the intermittent info.
Aug 05, 2013 | 1992 Ford Explorer
I want istall my printer and scanner
Hello
OK, unfortunately you do not specify as to which printer and scanner you want to install, hence, we cannot provide you with the correct driver. Also, you will need to specify as to which operating system you are using.
Just leave a comment on the details requested.
Kind regards
Andrea
Aug 27, 2010 | Computers & Internet
Which button is flash on a LG VX8350?
WES, There is never any button for the flash. It is connected to the shutter button of the camera. the idea is that the flash has to go at the exact moment when the shutter opens. Hence it can only be controlled electronically. If you want to operate the flash, the in the camera settings you must activate the flash (as auto). Whenever the flash is needed as per the light conditions. it will operate.
Aug 24, 2010 | LG VX8350 Cellular Phone
Operating light, indicators or brakes causes
Hi and welcome to FixYa,
Initially, check / clean the connectors of the charging system; from stator to rectifier/regulator combo to battery. Preliminary suspect would be undercharging hence any additional electrical load robs the ignition power causing the misfire..
Offhand, use a voltmeter to test idling voltage and charging voltage. Postback results.
Good luck and thank you for asking FixYa.
Nov 20, 2009 | 2001 Suzuki AN 400 Burgman
Red light flashing and noise
The user manual states the flashing red light signals that your transportation lock is on. Look underneath the scanner and you'll see a switch for "lock" and "unlock." If the switch is turned to "lock" move it over to "unlock" and plug the usb cable back into your computer. It should work with no flashing red light. If not try restarting your computer and plugging it back in again.
Mar 30, 2009 | Epson Perfection 2480 Photo Flatbed...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Intermittent Beep
check door switch is operating and the light switches off. an easy way is to prize back the seal a bit with door closed and if light is still on you can see it
Jun 21, 2007 | Zanussi ZX97 / 5 Bottom Freezer...
HP ScanJet 5370C Flatbed Scanner Logo
331 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
