Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washer wont fill model number wtw57esvwo
  • Anonymous Mar 15, 2014
    wont fill with water but will run through cycles
  • 1,998 Answers
U mean wont fill with water first thing to check is your water valve fromthe inside take a multi meter and make sure you have power going to and fromthe vavle remove the leads that plug into the vale and test eachone that they have power if it is not you watervalve the next place to check would be your timer 90 percent of the time it is your water valve that goes bad you can order either part from marone appliance parts and they will send it directly to your door hope this helps
Posted on Jul 21, 2010
How can i tell if my door switch on my whirlpool washer machine is working? my machine does nothing when i turn it on.
I cant say for sure the right color of the wires but one is a ground and its attached to the body leave that one alone, jump the 2 other wires on the door witch harnest together to bypass the door switch and see if it runs
Oct 05, 2014 | Whirlpool Washing Machines
Whirlpool Model WTW57ESVWO Will agitate but will not fill with water
There is a water fill sensor that can go and needs to be replaced. Also check the intake screen make sure it is clear sometimes that will get clogged. Whirlpool W10292584 Switch Sen AppliancePartsPros com
Apr 14, 2014 | Washing Machines
Whirlpool wont spin on rinse cycle
What is the model number??
Jun 28, 2013 | Washing Machines
Washer wont run
What is the model number of the unit?
Nov 06, 2012 | Whirlpool Washing Machines
I have a Whirlpool WTW57ESVWO that is acting up. It used to fill with water before the wash cycle started, now it starts together. Also, the spin cycle will be finishing and it will start filling with...
This sounds like a bad timer. This can occur if the unit is heavily used and/or it's over 5 years old. See this link for a parts breakdown (see part #9) under Controls.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5513874&diagram_id=28141944#d28141944
Disclaimer: I do not work for, have no affiliation with, nor represent this company. This is not the only place where this part can be purchased.
Jun 11, 2011 | Whirlpool WTW5700S
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Wont spin
The whirlpool calypso was a lemon!!! if i were you i would buy another machine. They have many problems! Pumps go out very frequently and they are over 80 dollars. Save and buy a new machine... Sorry for the bad news.
Nov 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Barberboss
need more details please stopped what wont fill wont spin wont drain does it make any noise ?? does it fill and not wash
May 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
449 people viewed this question
Dan Webster
Dan Webster
Sal De
