Question about Kenmore Room Air Conditioner
Kenmore 18500 btu window a/c model 70181 brand new. Water in the pan is being kicked up by the fan making loud pinging noise as the water drops hit the inside of the a/c. Like the water level is too high and is touching the fan. It's I installed it correctly with about a 1/2 in downslope to the outside. There is no drain plug to let the water drip out. The manual said not to drill a drain hole.
2 Suggested Answers
  • 34 Answers
SOURCE: brand new kenmore air conditioner
The new Room A/C's do not have drains as it uses the condisation from the pan to help cool the coils this makes the unit more effecient.
Posted on Sep 01, 2011
Air conditioner kenmore energy saver model 58076081500
The water should be draining out. Check wherever the drainage is for a blockage and clear it.
Sep 20, 2013 | Heating & Cooling
Refrigerator leaking bad at bottom after manual defrost still leaking
Ah the bottom. The drain pan is overfull and can not Handel the amount of water going into it. Normal running operation will evaporate any water left in the pan. You can pull out the fridge and drain the pan or clean up the water until it stops. Good luck
Sep 09, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Brand new kenmore air conditioner 18500 btu, there is no place for the water to drain, no drain plug? water is getting high... model 70181
Sep 01, 2011 | Kenmore Room Air Conditioner
My unit is throwing water out of the front vents not a lot. It sound like the fan blade is hitting water It still cools but makes a loud noise .R bordeaux
The water and noise you hear is from the fan blades hitting backed up water in the drip pan. This occurs when the drain hole near the rear of the drain pan is clogged and/or the rear of the unit does not have enough downward tilt. Which allows the water to flow freely to the drain hole. The general rule of thumb for downward tilt is 1/4" to 1/2". Correcting these to things should solve the problem. Be sure to turn the unit OFF & Unplug it, before attempting remedial service work on the unit.
Hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Friedrich air conditioner
I used to be a "Factory Authorized" person, and I bet Friedrich would rather do a warranty call than have you return the machine for a refund. Phone them to see if they are cooperative. When the tech gets there, you can ask ALL your questions and point out every little sticky thing. That's his job!
The tech will be able to get parts and know how to adjust things.
For the second person, you have to look into the space where the fan is hitting something. A mirror and a flashlight will be needed. I kind of get a feeling the water isn't draining fast enough. Look for a plastic tube from the front water pan to the rear water pan. They get plugged up.
Jul 24, 2008 | Goldstar R1003 Air Conditioner
Heating & Cooling Logo
333 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
