Question about ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 19" LCD...
Turn the monitor on it flashes on for a mont then goes black
  • 1 more comment
  • Anne McClusky May 28, 2008
    on rebooting the monitor will flash on for a second then go blank. If I hit the on off button on the monitor it will again flash the screen for a second then go off again. ususally do that 8 or 10 times and it will stay on. Now I can't get it to stay on. traded it in to service for another monitor. The new one does exactly the same.
  • vht2150 Dec 28, 2008
    Had multiple electric interuptions and this was not on the UPS...
    Was fine (other than the on/off switch being loose. Replacable?).
    Anyways...
    Now video comes on and looks normal for about 3 seconds upon each different booting screens, and then shuts backs off :( Apparently the power supply got damaged? Odd that it even works at all...
    Any suggestions?
    That board replacement is not available now from Viewsonic it seems.
  • Anonymous Jan 04, 2009
    I have exactly this problem with exactly this monitor. I've taken it apart and don't see any cold solder joints. T1 shows no signs of failure, so how can I determine whether that's the source of the trouble?
    Problem Solver:
  • 6 Answers
I had the same exact problem. I pulled the power supply/inverter board out and found what alot of people have seen. The T1 transformer has blown. Replacement board link here.
Posted on May 17, 2008
  • 975 Answers
It could be a DRY SOLDER , open the monitor , check the PC board , specifically where you see a small transformer ,do some resoldering around that area ,that should take care of problem . good luck
Posted on Apr 22, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
Va912b monitor flashes on for a second then goes black, how can I fix it? I need immediate help.
Please see my pictures here if you are going to DIY repair: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA912B/
Common problem in LCD monitors, see other failed Viewsonic and other brands in my albums.
Please post back what you find so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 19, 2010 | ViewSonic VA912BWB 19" LCD monitor
My viewsonic monitor flashes on (with the picture from my computer) and then off. It will nto stay on. If I turn it off and turn it on again it will flash the desktop and then turn off. The flash if for...
kdbooks, CCFL lamps could be weak (tired) or switch-mode-power-supply"/"ccfl inverter-supply" may need rebuild. Read my fixya profile for a while. Reading is free. Your ccfl back-lit lcd display is no different than any other brand in it's basic design and operation!!! Follow all links found on fixya. See how lcd displays are repaired to determine if you are capable of DIY repair to your Black or Blank n Black screen unit!!! Read the older (pg.15 and up) and you will understand all your options. Visit youtube. If unit out of warranty, then you will need to make decision on contracting out the needed work or if you will DIY repair!! Good luck on your quest. 12fixlouie
Mar 27, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
My ViewSonic VG1930WM (Black) LCD Monitor wont turn on
You need to open it up and the first place to look will be the power supply, look for bad caps with bulging top, post back what you find so we can guide you further. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | ViewSonic VG1930WM LCD Monitor
My monitor(Viewsonic VA912b) flashes on and then goes to a black screen. Anyone know what is causing this?
Could be a few things.
It could be the resolution settings.
It could be that your monitor isn't connecting to your computer. In this case you would have to get a card for the monitor to plug into.
It also could be that it's not supported by the OS.
Jul 11, 2009 | ViewSonic VA1912wb 19" LCD Monitor
I have a ViewSonic VE910b 19" That the display stays black
What your both experiencing is a slow degradation of the inside light bulbs. Just like what happens to regular fluorescent bulbs, they slowly flicker out.
Best to buy a new monitor.
Take apart your old one, you'll find burnt out bullbs on the upper and lower chassis deep inside.
Apr 22, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
ViewSonic VX910 19" LCD Monitor Logo
269 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
