GoVideo DP5040 Portable DVD Player Logo
Posted on Apr 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LOST REMOTE CONTROLL CANT RESET PARENTAL CONTROL PASS WORD
CANT PLAY DVDS DUE TO PARENTAL CONTROL CODE
ALBERT GARCIA
Level 3:
  • Master 975 Answers
  • Posted on Apr 22, 2008
ALBERT GARCIA
Master
Level 3:
Answers
975
Questions
5
Helped
358420
Points
2970
Try to go to their homepage : www.govideo.com/?GV=DP5040 since it a no longer available item. good luck
3answers
Parental controls
try giving the reset ...........
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
2answers
Need master pass code to a ps2 to play movies
There is no master pass code, but there is a code to reset the parental settings. It's important to note that 7444 is NOT the password. You have to hit SELECT when asked for the password. That is where you enter 7444 to clear the code.
Here is the procedure to reset the parental lock code:
Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
When the screen asks for the code, press the SELECT button, then enter in the code "7444".
The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
6helpful
Parental code lock sony kp51w5500 reset /or clear it?
If you lost password of parental code then put 4357 and press Ok
This will clear old pass word and type new password.
The parental control is on and cant play games. dont know passwords
Go to Settings
Highlight Parental Control
When the screen pops up that says Enter Pass Code press: X, Y, Left Trigger, X
You'll be taken to the parental controls screen where you can disable the passcode previously entered.
don't tell your mommy on me now...lol
Parental control
hi crakmonk
At the screen where it ask you to imput the password enter 7444. the old password will be deleted and you will have to setup an new one.
Just leave it blank to not have a password setup.
or look here for more info Open Tech Support - Playstation 2 Parental Control Reset/Bypass
riz.
LOST REMOTE CONTROLL CANT RESET PASS WORD
try to go to their homepage for assistance ,since this item no longer available,heres the link : www.govideo.com/?GV=DP5040
Parental control code>>>>>
load without disk in drive when browser pops up choose version setting
look in there
5helpful
3answers
Parental control code lock tv
I am not sure if this works for your model, but if you have the original remote, turn the TV on, point the remote at the TV and press the "QV" (quick view) and the "9" buttons at the same time. Let me know if that works.
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
