Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Need help!!!!! I read the manual and tried my new hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Need help!!!!!
I read the manual and tried my new Hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You could have a bad water release valve on your water tank of which holds the water, the trigger assm might not be connected, bent or broken. Check the trouble shooting owners manual --- also there are hoses that could be crimped or bent, or clogged or not connected, but it is my guess it is the water release valve. Try to back track the water from the holding tank and test all the valves on the system and you might find the problem by the process of elimination. Feel free to contact you local vacuum cleaner dealer in the yellow pages or contact the Hoover Co @ the information listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Posted on Apr 22, 2008
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
My hoover F5515 was working fine but when I pulled out the tsnk to remove dirty water and place it back and turned it on, brushes stop rolling.
Hello Sonny! If the dirty water tank is not put back on securely it will prevent brushes from spinning. Take off the dirty water tank and replace it making sure it locks onto the cleaner and is flush. Now check your brushes for obstructions. Remove all hair and debris from the brushes. If the brushes still will not spin take your cleaner into a Hoover authorized service center for repair. Follow the link to locate the nearest service center in your area. Hope this was helpful!
Service Center Locator
Oct 19, 2014 | Hoover F5505 SteamVac Spot Vacuum
I followed the trouble shooting advice for a Hoover steam vac that has non-spinning brushes. Turbine ordered and replaced. Female receptacle still is not spinning. What now?
There could be several reasons for this. Remember that the brushes will not turn unless the dirty water tank is in place. Also the handle must be released and tipped back. It is also possible that the rubber seal that the lower tank sits on is missing. If you look down into the motor area, there should be a large, round rubber seal that the lower tank sits on. Look for the round tube that protrudes from the bottom of the dirty water tank. This tube sits against the seal. If it is missing it will need replacement.
Jul 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Deep Cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40578&thid=661545
Hoover SteamVac Deep Cleaner
Posted by Alex987 on Jun 10, 2008
I can't seem to figure out how to use it =(
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5807 SteamVac Wet/Dry Vacuum. Well, there are 2 tanks, one is the water solution tank that is on top and the other is the water recovery tank of which is on the bottom. You use the trigger assm to release the water and the Hoover SteamVac works the best on the pull back. You can spry the water going forward but pull it back very slowly and let the brushes do the scrubbing for you and the dirty water pickup. There is a ball in the dirty water pup tank that will rise to the top and stop the water from coming in, @ that point you need to empty and rinse out the recovery tank and re-install. If you run out of solution the top tank cap or cover is the measuring cup to determine the amount of solution – usually it is one cap full and extremely hot water, there is a switch for the carpet and the upholstery, if the handle is in the released position then the brushes down below should be moving – just look in the brushes window and see if they are moving – if the handle is in the upright position then you can remove the attachment hose and then use the attachment and the revolving brushes will stop. I hope this will help you in working with the Hoover SteamVac. If not contact the Hoover Co and get an owner’s manual and give them the model # and serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Hoover steamvac clean surge turbo power 5200 attachment problems
That part to install in tank, is at the end of your hose. Take the lide off of the dirty water tank, on the front of the tank, there is a block that will slide out, then you can insert that part in its place. You have to have suction to make the brushes spin, so you just need to put the block on the end of the hose in the slot on the front of the tank. When down however, put that block you took out back, or your cleaner won't work right.
Jan 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
131 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
